Offroad & 4x4
Truck wandering
Old Jun 28, 2003 | 01:54 AM
Ryan50hrl's Avatar
Ryan50hrl
Truck wandering
ok, my truck started doing something really weird. about once a day when driving now, when i turn a corner fairly sharp, my truck tries to steer itself, where it is nearly impossible to hold the steering wheel straight. It almost trys to turn itself. anyone else have this happen? all the front end parts are good, i was thinkin i'll check the pivot bushings tommrow, any other ideas?
Old Jun 28, 2003 | 08:36 PM
RCrawler's Avatar
RCrawler
Truck wandering
Check the lift drop brackets for loose mounting.
Jason
Old Jun 30, 2003 | 12:19 AM
Ryan50hrl's Avatar
Ryan50hrl
Truck wandering
checked those already, checked pivot bolts, front end parts, radius arm monts and steering stabilizer.....any other thoughts?
Old Jun 30, 2003 | 01:46 AM
bronco351's Avatar
bronco351
Truck wandering
Maybe the steering gear box is binding up. I just replaced mine on my 1990 Bronco. It definetly helped out in getting firmer steering. I had to replace mine due to a major leak! Hope this helps you some!
Old Jun 30, 2003 | 08:55 AM
fishin1976's Avatar
fishin1976
Truck wandering
check the intermedate shaft from the column to the steering box for wear, missing bushing or play.
Old Jul 6, 2003 | 12:29 AM
StephenKnight's Avatar
StephenKnight
Truck wandering
if it is maby its trying to go get a hamburger or it might want gas or something
bruno2
Mar 29, 2017 06:42 AM
funfunstuie
Jan 5, 2017 05:33 PM
invstr55
Sep 11, 2016 04:53 PM
F3fitty
Oct 3, 2015 06:57 AM
MUSKRATT2
Sep 15, 2009 07:05 AM
