Sponsored by: Real Truck
my traction problems are gone
Old Jan 23, 2014 | 07:29 PM
nojoke327's Avatar
nojoke327
Since I sold my sander my *** end has felt very light with the plow on and it is pretty useless unless its in 4x4. I pass by a concrete plant that is near my house every day and I decided to stop in to see if they would sell a chunk that is scrap. Well they ended up giving me this retaining wall block that was casted wrong for free. It weighs 2300lbs and is perfect for traction. This morning I couldn't get out of my driveway in two wheel drive but this afternoon I got out fine.
The truck is squatting a little bit with the plow up it is almost level
Old Jan 23, 2014 | 07:33 PM
Bigpipes 35's Avatar
Bigpipes 35
Nice but how you gonna get it out in the spring?..
Old Jan 23, 2014 | 07:36 PM
JWC 3's Avatar
JWC 3
Yes , how do you plan to unload it .
Old Jan 23, 2014 | 07:37 PM
nojoke327's Avatar
nojoke327
I have a 4x6 bolted to 2 trees and a come along I used to take the sander out. I will beef it up a little and lift it out
Old Jan 23, 2014 | 08:20 PM
Joshwfl's Avatar
Joshwfl
Trailering
Nice. Growing up in NY we used old snow plow wear bars for weight. I kept a 4x4 running across the front of the bed, but always worried I'd slam on the brakes and have one come slicing through the back of the cab.
Old Jan 23, 2014 | 09:27 PM
nojoke327's Avatar
nojoke327
Ya I would worry about that too. I have 2 5000# starps holding this block in place but if it wants to go I don't think much would stop it
Old Jan 24, 2014 | 01:18 AM
Bently_Coop's Avatar
Bently_Coop
Looks like a good idea. Thanks for sharing.
Old Jan 24, 2014 | 04:44 AM
Yahiko's Avatar
Yahiko
FTE Remembers
For the occasional driver you might try a snow shovel. Fill the
bed up with snow. Soak it with water and let it freeze.
My name for that mix is self depleting ballast.
Not the same 63± Lb per Cubic foot as water but it helps.
Sean
Old Jan 24, 2014 | 09:45 AM
99f350sd's Avatar
99f350sd
Ya weight makes a big difference.. Only problem is it has to be over 1000 lbs or so..2500 is prob just right with a plow on the front.
Old Jan 24, 2014 | 10:49 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i was going to buy this
Old Jan 24, 2014 | 10:51 AM
nojoke327's Avatar
nojoke327
Ya my sander was a 1000# empty and it didn't make a huge difference. Once I filled it with 2-3000# of salt it was much better. This weight is perfect though. Traction is amazing. I just drove through my yard with 8" of snow with no issues. Before I wouldn't have made it 10 feet
Old Jan 24, 2014 | 10:55 AM
nojoke327's Avatar
nojoke327
I had looked at those as well but I worried that if I needed to put any tools or lumber in the bed it would pop it.
Old Jan 24, 2014 | 11:01 AM
SuperDutyScaler
when i was looking at buying it i thought it said on their website it has a 500lb payload capacity...
Old Jan 24, 2014 | 12:14 PM
nojoke327's Avatar
nojoke327
If you can put 500lbs behind the rear axle it will help but being spread out like that I don't think it will make much of a difference.
DieselCamper
15
Oct 1, 2016 10:01 PM
youknowitdadio
Dec 22, 2012 08:36 PM
stranskydw
Delaware Chapter
Jan 29, 2010 12:55 AM
Milwaukee1979F150
Jan 4, 2010 05:28 PM
