Your link looked like the oil returned at the Oil Filler Tube
The Kit I posted with the Centrifuge returns oil into the Valve cover
I know the Early HPOP Shears Oil I can see it in the way it Operates
BUT IDK about the 05+ HPOP they work differently it may or may not shear oil IDK enough to say. It could be the Case the 05+ HPOP shear oil but at a Lower rate then the 03-04 HPOP does since the 05 uses a Piston and Cam to create HPO
mines an '04, I looked at the link you posted. looks interesting as well. I figured a little proactive maintenance is better than reactive maintenance.
[quote]
Utilizing a full synthetic oil and oil sampling, it is completely feasible to see 100,000 mile oil change intervals. This is due to the fact that synthetic oils do not wear-out or break down like conventional oils.
[\quote]
I guess these folks are from Colorado, and smoking too much…
The ebay link for NUCmotorsports.com states (FOR the 6.0)
[\quote]
x2. I would agree, it you really wanted to have better filtration that's fine, but as has been repeatedly stated, you shouldn't extend your OCI (oil change interval)
