Y block starter issue.
Old Jan 23, 2014 | 05:01 PM
MGannaway's Avatar
MGannaway
i have a 61 c-550 with a 292 y block. No one in town could find that in their computer so I took a chance on a starter from a 64 F100 with 292 and this is the two next to each other. The new one has extra studs and nuts on it and I believe they are what is interfering with the starter not seating flush.
any ideas?
Old Jan 23, 2014 | 06:54 PM
MGannaway's Avatar
MGannaway
I made a hybrid of the old and new. I cleaned the armature and used all the new brushes and magnets. But here is a pic of the starter now installed. It looks like the gear is already engaged to the flywheel. I am not sure if the old bendix is messed up or if that is how it is supposed to be. OR maybe it wasn't the right starter either. Hell if I know now.
Old Jan 23, 2014 | 07:05 PM
Y-Blockhead's Avatar
Y-Blockhead
Have you tried starting/cranking it? I think once it starts the drive will kick out because it appears that it was in the engaged position to start with (first photo).
What I find strange is the difference in the length to begin with (again in first photo), like the shaft is too long on the new one. It's been a long time since I've actually looked at a Y-Block starter, I have a FE starter on mine.
Old Jan 23, 2014 | 07:13 PM
MGannaway's Avatar
MGannaway
From what I read there is a couple different length Bendix for different bellhousing/flywheel combos. My starter relay clicks but no action. I am about to try a jumper cable straight to the starter.
Old Jan 23, 2014 | 07:20 PM
MGannaway's Avatar
MGannaway
SUCCESS! A jumper cable straight to the starter made her hum right along. Now its time to put some plugs back in it and add some fuel
Old Jan 28, 2014 | 10:26 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Y blockhead,
What did you have to do to change to a FE starter?
Old Jan 28, 2014 | 11:41 AM
Y-Blockhead
Hi BJ. I have a C-4 automagic behind my 312". The Flat-o bell takes the "newer" type FE starter.
Old Jan 28, 2014 | 12:04 PM
bjmayberry2
I bought a Car Flat o bell and flywheel at a swap meet and sent it out to Gene to have "wings" welded on. He sells a hardware kit with all the bolts and Bendix to swap to a FE starter. Just looking for options.
DrZoom
16
Apr 6, 2016 11:42 AM
elrod2020
Sep 12, 2007 08:24 AM
jhuffer
Aug 9, 2003 02:01 PM
