transmission flush question
Unhook trans lines. Hook a pump to the line that runs to the cooler. Pump in new transmission fluid and catch the old coming out of the other line. Its pumping fluid in reverse and when they do that they say they do not have to change the internal filter because it flushes the crap the filter has caught out of the filter. Ive had done once and will not do it again. Now that was from the ford dealership here in town. Since you are an expert at transmission repair maybe you can shed some light on the subject. I may of been misled.
IMO there has to be a problem already existing for a flush to make it worse.
Perhaps my transmission had issues before the flush, however, if it did it never gave a moments problem until after the flush. Gota love that timing.
That said, if you have your transmission flushed, please let us know and document the mileage and let us know how it works out. Such will be a good test. Be sure to document the flushing method and technology also if you will.
I have heard some say transmissions have check valves in them and only allow fluid flow in one direction. If true, they cannot be back flushed.
As for changing engine oil verses flushing transmission oil; two totally different technologies.
It is impossible to backflush a transmission. If you try to pump fluid in the opposite direction to normal flow the pump will act as a check valve and prevent any reverse flow. The only way around that would be to run the engine backwards. Engines do not like that.
The only way that a transmission can be flushed is in the normal direction. The machines that connect in the cooler lines remove the old fluid from the line as the transmission pumps it out and replaces that fluid with new fluid right back into the other end of the line that was disconnected. It does not stir up any more junk than running the engine does.
They are right that the internal filter doesn't need to be changed (unless you have a 2008 Job #2 or newer) because it is a lifetime filter. If that filter needs changing it is because the trans has already failed. But they are NOT flushing the crud out of the filter. The crud isn't there to begin with.
Most people drain and refill at least 3 -4 times for the at-home flush. Be sure to drive it in between drains and get the fluid fully up to temp so the fluid mixes well. IIRC you are looking for 170 degrees as the target temp. It is not hard to get 85 - 90% of the old fluid out this way.
Be sure to change the external filter also. It is not any cheaper to do it this way, but sometimes you can't find anyone with a hot flush machine. I do it 4 times (apprx 7-8 quarts each time at $6.50 per quart)
