Sponsored by: Real Truck
weird sound
Old Jan 22, 2014 | 09:23 PM
GreatWhite7.3's Avatar
GreatWhite7.3
weird sound
i have a 2001 f250 7.3 4x4 today i locked the hubs, put it in 4 low and got threw some mud to go hunting fine. got back out of the woods and took it out of 4x4 unlocked hubs and went in reverse 30 yards.. now when i drive it makes a weird sound like a rubbing sound near the front axel..anyone know what this is?
Old Jan 23, 2014 | 06:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
You don't need to back up to unlock the hubs.
Does the truck make this sound when the hubs are locked?
Old Jan 23, 2014 | 08:13 AM
spongecop's Avatar
spongecop
Semper Fi
maybe got some debris up in the wheel/brake area?
Old Jan 23, 2014 | 08:27 AM
Bobbykjl's Avatar
Bobbykjl
That's my thought also. Being you were in the woods, you may have picked up a stick in between the inside of a rotor and the steel rotor splash guard. Even more likely something kicked up and bent the splash guard and it's now touching the rotor. Easy fix, reach down grab the guard and pull it away from the rotor. If it's to hard use a wedge or screwdriver.
The other possibility is the hub did not release all the way. Another fairly simple fix. Remove the hub assembly (one big clip on the outer circumference). Clean it up, check for damaged parts and put it back together.
Here's a link that is a full procedure to rebuild your hubs
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Jan 23, 2014 | 11:39 PM
GreatWhite7.3
Now it's in 2wd... makes noise until truck worms up right when I start going it screeches. ..
Old Jan 24, 2014 | 04:13 PM
spongecop's Avatar
spongecop
Semper Fi
still thinking brake or bearing related. I have had crud, small rocks and sticks get crammed in there after driving in mud/woods etc. I would take both wheels off, pop calipers off and inspect everything real close.
RyanGruhn
1978 - 1996 Big Bronco
Aug 7, 2013 06:18 AM
Downriver Thunder
Mar 26, 2006 11:54 AM
Sf006
Nov 23, 2003 01:48 AM
bsat
Oct 21, 2003 05:52 PM
swenson
Apr 13, 2003 08:42 AM
