Sponsored by: Real Truck
4x4 problem
Old Oct 21, 2003 | 02:41 PM
bsat's Avatar
bsat
Question 4x4 problem
REcently purchased a 250 fx4 with locking hubs and shift on teh fly. The hubs are currently in auto mode. When turning it makes a clinking sound. I don't think this is normal. Any input?
Old Oct 21, 2003 | 03:36 PM
99f350sd's Avatar
99f350sd
What year? How many miles? There could be any number of problems from bad hubs to bad ujoints..
Old Oct 21, 2003 | 05:52 PM
RRMike's Avatar
RRMike
Check and see if the front axles are turning. If they are you have a hub stuck. If they are not you most likely have a hub that is partially engaged. It's the splines on the stub shaft making contact and causing that clicking sound.
