Simple question - can SCA be added to the overflow tank?
Old Oct 17, 2018 | 10:54 AM
BrianV_'s Avatar
BrianV_
I just tested the coolant in my 'new to me' 1988 F250 with Wix 24106 test strips.
It looks like brand new coolant in there, bright green and tested at 60% glycol and a PH somewhere around 7.5, which makes sense as the radiator was recently changed before I purchased the truck, and the truck has been off the road since.
However, it tested as having no SCAs in it. I'm assuming I need to add some, but my first question is - can I just add them to the overflow tank, or should they somehow be added to the rad (which is full to the cap level).
A second question just occurred to me - is there anyway to check whether I have some sort of unknown ELC in the truck? I mean, it's green and looks / feels like traditional coolant, but now that there are green ELCs, how would I know?
Old Oct 17, 2018 | 04:07 PM
Dieseloholic1's Avatar
Dieseloholic1
I added my SCA to the overflow it will mix in eventually my radiator was full as well sorry I don't have an answer for the ELC
Old Oct 17, 2018 | 04:11 PM
ford390gashog's Avatar
ford390gashog
If it's that full just take the radiator cap off when cool and put your hand over the cap neck. Squeeze the upper radiator hose and it pushes coolant to the overflow creating enough room for the SCA's. Also worth mentioning if it tests negative for SCA's its probably not a heavy duty diesel coolant and not nitrate free. Hopefully it isn't translucent green AKA Prestone universal.
Old Oct 17, 2018 | 09:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
If you don't know what's in there,then I'm afraid it's best to flush it.Although it very well may be a good traditional green coolant,if you add SCA's to that,they wont work but instead turn your coolant mushy and you'll have to start over anyway.
You can use a standard green coolant if you want,just make sure to get one that states low silicate.
Old Oct 18, 2018 | 05:16 AM
Dieselamour's Avatar
Dieselamour
This gets a + 1 Vote from me.
96_F250_Deezal
Jan 23, 2014 09:19 PM
stan'37
Aug 27, 2012 06:11 PM
aa777888
Apr 10, 2005 01:45 PM
pcerra
Feb 21, 2004 08:14 PM
F0rdF0rever
Sep 15, 2003 10:28 PM
