ficm question
Old Jan 22, 2014 | 06:14 PM
351crules's Avatar
351crules
ficm question
i,ve been getting a balance contribution code for #5 injector almost every time i start the truck cold...also get a #2 one every once in a while...i recently installed a high amp alternator and have yet to get a balance code in 3 days time...my question is..do you think the higher output alt is masking a potential problem with in the ficm since the issue has seemed to went away....i've never had a voltage reading less than 47.5 if that matters....thanks for any input
Old Jan 22, 2014 | 08:32 PM
npccpartsman's Avatar
npccpartsman
It could simply be that a simple FICM flash will improve your starting issues. What kind/weight of oil are you running?
Old Jan 23, 2014 | 08:12 AM
351crules's Avatar
351crules
5w-40 with rev-x... it starts a lot better with this new alternator...just found it odd that the injector codes went away after the install
Old Jan 23, 2014 | 12:38 PM
Mr.Nobody's Avatar
Mr.Nobody
I would also throw out there, put the batteries on a charger. Get them all topped off. I went through this a couple months back. Repaired FICM, 185amp alt, 2 new batteries. Some of the best money spent on my truck to date.
hobbystock98
Apr 15, 2013 02:03 PM
JCark
Nov 27, 2012 07:34 AM
Fulthrotl
Aug 2, 2012 01:41 AM
jkinghorn6.0
Apr 22, 2012 09:09 PM
PsD007.3
Mar 25, 2009 12:00 PM
