Coolant flow/bypass question
Old Jan 22, 2014 | 08:26 AM
Tudunka's Avatar
Tudunka
Gentlemen,
I too am looking for a Coolant Kit, but I do have a question. I have a 04 6.0l Diesel and live in Texas and it gets pretty hot here and the cab gets hot from the heater core when you first turn on the cooling fan (A/C) even with the temp setting all the way to cool. So I installed two ball valves to cut off the coolant to the internal heater core (1 going in & 1 going out) during the summers. Now to keep the coolant system moving, I will on occasion turn the valves back on to let the coolant circulate, but most of the time I keep them closed. My question leads to this - in reviewing most Coolant Filter Kits, they tie into the Heater flow hose and into the Coolant Bowl. If I have closed the heater core down, will the Coolant filter kit work or is there another way to hook up the Filter Kit?
Thanks Fellas.Andy
Last edited by Tudunka; Jan 22, 2014 at 08:30 AM. Reason: for got to add something
Old Jan 22, 2014 | 11:55 AM
Stewart_H's Avatar
Stewart_H
Tudunka, I cut your post from the thread you posted in and moved it to the 6.0L forum where the guys who specialize in the six-oh can help you with your question.
Welcome to FTE!
Stewart
Old Jan 22, 2014 | 12:13 PM
Misky6.0's Avatar
Misky6.0
As long as you tie in to heater hose BEFORE your valve it should work.
The excursion (and i think crewcabs) have a vacuum activated shutoff to the heater core to automatically do what you do manually.
Sent from my Sprint PC36100 using IB AutoGroup
Old Jan 22, 2014 | 01:26 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
My 06 Supercab XLT has the vacuum valve on the heater supply line.
As for the filter, install it before the ball valves so it has full coolant flow
Josh
Old Jan 22, 2014 | 03:55 PM
BLADE35's Avatar
BLADE35
Here is a Pic of the Vac Valve these Guys are talking about
This Valve Cuts off the HOT Coolant from entering the Cab when the A/C is On
Old Jan 23, 2014 | 03:27 PM
Tudunka's Avatar
Tudunka
Hi Fellas,
This was PERFECT - just what I needed to know and thanks for the Pic by Blade35 that was great. I put my ball valve just beyond the bend where the vacumn valve is and the hose goes straight - it was easy to put in.
I have a diesel shop doing a EGR delete and a new Oil Cooler for me and I want to put in a coolant filter to keep this from getting clogged up again.
Thanks A Lot to all of you.
Andy
coolfeet
Jan 8, 2019 10:17 AM
Nitrous
Jul 23, 2010 09:17 AM
6LPSD
Jan 7, 2009 07:53 AM
gross30
Dec 31, 2007 06:05 PM
sstipiotis
Feb 21, 2007 07:04 PM
