F250Hd AC fix
Old Jun 27, 2003 | 05:29 PM
carpe_diem's Avatar
carpe_diem
F250Hd AC fix
1989 F250hd. The AC system was disconnected on this truck when I got it. I was told it is not working. What are the typical failures in AC systems of that year? Is this something I can fix with junk yard parts? Replacing the compressor maybe? It is too expensive to replace the entire system with R-134.
Old Jun 27, 2003 | 05:40 PM
luckild's Avatar
luckild
F250Hd AC fix
most common problem is hoses and o-rings.check system out. check compressor to see if it turns over and check for leaks.such as oil and grime on hoses or their connections.good luck.
Old Jun 27, 2003 | 05:53 PM
rebocardo's Avatar
rebocardo
F250Hd AC fix
Usually the compressor clutch has gone when someone totally disables it because they do not want to fix it and recharge the system. You can test that with some fused 12 volt leads.
Yes, junkyard parts are fine for a fix. Many yards have good compressors sitting on a shelf. The entire system is probably empty now, converting it is no big deal.
Old Jun 27, 2003 | 11:54 PM
carpe_diem's Avatar
carpe_diem
F250Hd AC fix
One more fact: The truck has been driven very little over its life. I wonder if it contributed to failure.
Old Jun 28, 2003 | 08:02 PM
68torino's Avatar
68torino
F250Hd AC fix
Just a question: To change out the clutch on an ac unit. Do you need to remove the unit? Or is it better to swap out the whole thing?
JoeM1965
Mar 5, 2015 01:30 PM
JoeM1965
Feb 19, 2015 12:43 AM
cousinjc
Jun 24, 2010 11:38 PM
briand7283
Jun 2, 2010 03:15 PM
rogerpyron
May 3, 2007 11:07 AM
