1997 F250 HD
Old Feb 16, 2015 | 11:56 AM
JoeM1965's Avatar
JoeM1965
Smile 1997 F250 HD
Any schematic of AC system components for my old-style F250 HD? Would like to see what other components I should replace in addition to the ac compressor...it just died. Any help would be greatly appreciated!
Old Feb 16, 2015 | 04:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucks forum.
Old Feb 16, 2015 | 06:43 PM
'89F2urd's Avatar
'89F2urd
the only other thing that is good to replace is the drier. theyre pretty cheap and easy to replace. its the aluminum (or steel) cylinder in your engine bay. follow the lines off the compressor and youll find it.
that's assuming all of your other components are in good shape - lines, condenser, evaporator. the condenser is in front of your radiator...just check it for corrosion or destroyed fins etc.
Old Feb 16, 2015 | 08:01 PM
TexasGuy001's Avatar
TexasGuy001
After replacing components don't forget to clean the system and pull vacuum on it.
Old Feb 17, 2015 | 08:22 AM
JoeM1965's Avatar
JoeM1965
great info!
So, checked the condenser...it looks solid. Will replace the hoses and the evaporator core along with the dryer and compressor...sounds like I should be good to go! Many thanks!
Old Feb 17, 2015 | 08:48 AM
'89F2urd's Avatar
'89F2urd
Evaporators are the last to go, they're well protected from the elements. I won't stop ya from replacing it though, 20 year old parts who knows what's inside it.
Old Mar 2, 2015 | 03:36 PM
JoeM1965's Avatar
JoeM1965
I am planning on replacing the core...mostly because I'd noticed restricted air flow...thought it was the blower motor, so I replaced it. No noticeable change...and now that the compressor has died, figured I'd go ahead with replacing the core. Any suggestions on how to get it out of the black box in the engine compartment?
Old Mar 5, 2015 | 01:30 PM
mrrish79's Avatar
mrrish79
Wish I lived in place that I needed AC in my truck right now!
jackstar
Mar 2, 2019 04:15 AM
real_texan
Aug 31, 2015 05:53 PM
Syntheglass
Aug 24, 2004 11:18 AM
Proteus566
Sep 22, 2003 01:43 AM
trucklover
Dec 2, 2001 04:27 PM
