Sponsored by: Real Truck
AC Odor
Old Jun 1, 2010 | 01:03 PM
briand7283's Avatar
briand7283
AC Odor
Need some advice......I have 2006 F250 with an AC odor.....not a good odor either.
It started with a fuel smell coming thorugh the vents. This was fixed by pressing the button that circulates air within the cab. Not a perminant fix but it does help avoid the smell.
Then the vents started to smell like a dead cat / dirty diaper combination.
AC still cools fine....My question is this....is there a filter for the AC system that can accessed and replaced. I have not been able to locate one as yet.
Old Jun 1, 2010 | 01:12 PM
WestxSRT10's Avatar
WestxSRT10
Your AC evaporator drain may be plugged and not allowing the condensate to drain outside. Compressed air and a small flexable wire could be used to unplug it.
Old Jun 1, 2010 | 01:26 PM
gearloose1's Avatar
gearloose1
Once it is unplugged...
If you can, a spray of fungicide / bactericide can do it.
Know GM makes a special spray that does the cleaning...
Don't know about Ford.
In a pinch, I would clean with a solution of bleach.
Old Jun 1, 2010 | 02:29 PM
GUNNERDOG's Avatar
GUNNERDOG
my dad had a mouse crawl up into the dash of his old BMW and die... i sure hope that isn't your problem...
Old Jun 2, 2010 | 05:43 AM
tnvnl's Avatar
tnvnl
If you have a fuel smell coming in with outside air, you should be looking under your hood for a fuel leak.
Old Jun 2, 2010 | 08:34 AM
briand7283's Avatar
briand7283
Thanks for your reply... that was my first thought as well but have not been able to locate a leak.
Old Jun 2, 2010 | 08:37 AM
briand7283's Avatar
briand7283
makes sense...........Is that something that i can do on my own or should i take it in for service?
Old Jun 2, 2010 | 08:40 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Fix the fuel issue first. Something is awry there. And dangerous.
If you still have a bad odor in the AC, as mentioned above, make sure the AC drain hole is clear.
Next, take a full can of Lysol disinfectant. Preferably the old original kind, not the newer "perfumy" smelling stuff.
Put the AC on, but NOT in MAX (or recirculate). Locate the air intake under the passenger side of the windshield (pretty sure it's there in the SD).
Spray Lysol liberally into the air intake. This WILL smell up the interior of the cab, but you have to completely soak the inside of the heater box. After you spray like half a can into it, shut it down, close up the windows/doors, and leave for as long as you can, up to 24 hours if possible.
Start it up again, spray Lysol into the air intake again, just like above. Use the rest of the can. Again, shut down and leave it as long as you can. A few hours maybe is good enough.
This procedure has worked for me multiple times in my own and others' vehicles. It's mold, bacteria, mildew, something, that Lysol will kill. It's the easiest to get your hands on, and probably a lot cheaper than the GM "air conditioner conditioner"
But check on the fuel smell FIRST.
Old Jun 2, 2010 | 08:42 AM
krewat's Avatar
krewat
Oh, I forgot something. After you make sure the AC drain is clear, spray some clean fresh water into the air intake, WITH THE AC/HEAT COMPLETELY OFF and make sure the water comes out the drain hole. If there's a buildup of crud in there, it may take a few stabs with a wire into the drain hole to clear it out.
Old Jun 2, 2010 | 08:50 AM
briand7283's Avatar
briand7283
perfect...thanks for the info... will let you know how it turns out.
Old Jun 2, 2010 | 12:35 PM
44dwarf's Avatar
44dwarf
I've used a similar product to this on an older car once.
https://www.ultrashield.com/products_AC.htm
got mine at local NAPA smelled like lemons
44
Old Jun 2, 2010 | 03:15 PM
mwsF250's Avatar
mwsF250
As stated, clean out the root cause and then de-odorize.
The extended family got together and purchased a MiST machine:
UView: Product Detail
Not cheap, but this thing works great, and leaves NO smells behind.
Fordfreek!
32
May 29, 2024 05:32 PM
FFJohn
Dec 11, 2016 11:56 AM
RLTotten
1997 - 2003 F150
Jun 11, 2016 10:43 PM
jippy
1983 - 2012 Ranger & B-Series
Mar 21, 2010 09:21 AM
YOMAN
2004 - 2008 F150
Jul 8, 2008 07:30 AM
