Clunk under truck
Old Jan 21, 2014 | 01:33 PM
Jamie Arceneaux's Avatar
Jamie Arceneaux
Clunk under truck
When I am coming to a stop in my E99 I hear a loud clunk under the truck. It can be felt by both myself and the passenger and it happens every time I slow down to a stop. Would this likely be U-joints? If so how to I check them to be sure? If not what else should I check?
Old Jan 21, 2014 | 05:56 PM
Ponyboychris's Avatar
Ponyboychris
You may want to look at the ball joints and sway bar ends.
Old Jan 21, 2014 | 07:25 PM
crop harvester's Avatar
crop harvester
check brakes & caliper bolts,lugnuts.
Old Jan 21, 2014 | 08:14 PM
SARDiverDan's Avatar
SARDiverDan
You should/might be able to get under there and look to see if a u-joint is cracked. When mine went out I noticed it the most whenever I put the truck in reverse and backed up a little. Sounded like someone was under there with a hammer banging on the driveshaft.
Old Jan 22, 2014 | 07:14 AM
DavidE's Avatar
DavidE
Front End Clunk
In my case had clunk happening when breaking at slow speed. Seemed to be from front end. Was ball joints. Now no more clunk. If you do a search you can find out how to check them.
Old Jan 23, 2014 | 12:33 PM
thomabb's Avatar
thomabb
Does it feel like a bowling ball is rolling around in the bed and is hitting the back of the cab right before you are completely stopped? If so,
1) Check the bed for rogue bowling *****, then
2) Grease the splines on your rear drive shaft.
Fordguy581
2004 - 2008 F150
Mar 14, 2018 08:54 PM
anthonym92
May 19, 2017 08:48 AM
RobH1965
Jun 16, 2010 08:19 PM
Duck Hunter81
Jul 22, 2009 01:10 AM
RTM
Apr 14, 2005 12:07 PM
