Small clunk or click when first applying the brakes - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Old 03-08-2018, 09:36 PM
Fordguy581
Fordguy581 is offline
Fordguy581 is starting off with a positive reputation.
My dad asked me to take a look at his truck, a 2006 f150 5.4L 4x4. It makes a small clunk when applying the brakes (only at low speeds like 5 - 15 MPH) and when going over speed bumps (not every time, maybe half of the time), it has about 118k miles on it. I thought it was the sway bar bushings and/or links but the sway bar doesn't move even with a pry bar. The click or clunk also happens during acceleration. I haven't been able to find out what it is yet. Also the ball joints, control arms and tie rods are solid, no play at all. Any help would be very much appreciated,
thanks,
Paul
Old 03-09-2018, 09:15 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Could be a broken caliper or caliper mounting bracket bolt. In either case it should be checked out and keep the use of the vehicle to an absolute minimum.
Old 03-09-2018, 09:29 AM
Fordguy581
Sure, I can check the calipers. I've looked briefly at the brakes and they look fine but I'll check closer. It just had a state inspection and passed just fine, I'll see if can check it out later my dad drives it everyday and never had any problems besides the small click. He says that the truck has been doing this for maybe the past month or so about 1k miles.
Old 03-09-2018, 11:30 AM
Fordguy581
I haven't been able to check it yet, when my dad brings the truck to my place I'll check it out.
my dad wanted to know how safe do you think it is to drive it, as he needs it for work and his other truck is in the shop for new brake lines.
Thanks again for your help,
Paul
Old 03-09-2018, 03:52 PM
1saxman's Avatar
1saxman
1saxman is online now
1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.
I don't think anybody here can tell you if its safe or not without knowing what's wrong with it. Sometimes the drive train will make a clunk on slowing or accelerating and the play could be in the front or rear axle or any other component of the drive train, like U-joints, transfer case, etc. You might even go over the wheel lug nuts just to rule out a loose wheel. Fords tend to break front coil springs which could conceivably make a popping noise when being loaded and unloaded. Personally I think it is related to the suspension/steering because it seems to be more related to suspension movement in response to bumps/braking/accelerating. Could be a strut that's loose at one end or the other.
Old 03-09-2018, 04:17 PM
Fordguy581
Sure, I understand that you can't tell without looking.
I might just take it to the dealership and have them see what it is. But first I'll check for loose bolts around the front. It does have about a ⅛" gap between the place where the sway bar link bushings are attached, so I might remove the sway bar and go for a short drive and see if the noise comes back.
Thanks for the help,
Paul
Old 03-09-2018, 04:32 PM
1saxman's Avatar
1saxman
The sway bar end links will do this exact noise if the bushings are degraded or the nuts need to be tightened. The support bushings generally won't make noise unless one is actually gone and the bar can hit the bracket.
Old 03-09-2018, 04:37 PM
Fordguy581
Ok, I'll tighten the end links, the bushings look like they are in good shape but there is a gap. The main bushings that connect to the frame look like they are in good shape too, and they have no gaps. None of the bushings are cracked or torn.
Thanks for the advice,
Paul
Old 03-12-2018, 01:26 PM
dbuck50
dbuck50 is offline
dbuck50 is starting off with a positive reputation.
I've had this happen and it took forever to figure it out. For me, it turned out that one of the brake pads debonded from the plate. it would literally shift back and forth--just a tiny bit. I couldn't have seen it without taking the brakes apart. I finally found it when I noticed the debonded pad wore unevenly..the front of the pad was wearing faster because it was cocking due to being loose from the plate. I find unless you go with a high quality pad, this isn't that uncommon these days.
Old 03-13-2018, 03:15 PM
jr105
jr105 is offline
jr105 is gaining momentum as a positive member of FTE.
I had the same thing happen to a brake pad on a Mustang that I owned and the symptoms were exactly what the OP described.
Old 03-13-2018, 10:23 PM
Fordguy581
I looked at the truck and the brakes are all tight, so I'm almost certain that it is the sway bar links, they are quite loose. I'll probably replace the links since after looking closely they seem worn out.
Thanks,
Paul
Old 03-14-2018, 09:56 AM
alloro
alloro is offline
Well at least that makes it much safer to drive.
Old 03-14-2018, 08:54 PM
Fordguy581
Yes, now at least I don't have worry about the calipers falling off (I was researching about that before I checked the truck)
gwcon
6.4L Power Stroke Diesel
09-17-2012 10:30 AM
bentring
10-24-2006 05:19 PM
slash12376
2004 - 2008 F150
15
06-07-2006 04:07 PM
74fordtruck
35
02-12-2006 09:24 PM
55forder
11-02-2002 10:48 AM
Quick Reply: Small clunk or click when first applying the brakes
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
