GAS Tanks
Old Jun 27, 2003 | 04:48 PM
tacson's Avatar
tacson
GAS Tanks
After asking around I have found two other OE gas tanks other than a Trooper that will allow one to mount the tank under the bed and run the filler out to the fender and out back in the sill below the tailgate. One is a Ford and the other is a C@#$%. The Ford tank that will work is a 70-77 Maverick or Mercury Comet. That neck on them came out in the center panel but with some persuasion it can be ran out lower into the lower and if you somebody would put one of the flip down license plate frame the filler neck and cap would be covered. The Chevy tank that will work is a 77-82 Chevy Van 22 Gallon tank. It is the smaller of the two that was available. The tank will fit between the frame if the rear crossmember is moved back some. A person has the optiion of positioning the tank so the filler neck comes out either on the left or right side. Mine will come out on the Leftside. Hope this helps someone along the way.
Old Jun 28, 2003 | 12:36 AM
ferguson777's Avatar
ferguson777
GAS Tanks
Tacson,
I am very interested in this info. Would you please clarify two things -
"70-77 Maverick/Comet ....but with some persuasion it can be ran out lower into the lower and if you somebody would put one of the flip down license plate frame the filler neck and cap would be covered. "
Plse clarify/correct what you mean in the portion "it can be run out lower into the lower"
ALSO -
"The Chevy tank that will work is a 77-82 Chevy Van 22 Gallon tank. It is the smaller of the two that was available. "
Do you mean that 2 sizes of tank were available in the 77-82 Chevy Van and the 22 gal. is the smaller of the two?
Thanks. Tidbits like this are very valuable to the forum.
Old Jun 28, 2003 | 01:14 AM
tacson's Avatar
tacson
GAS Tanks
Plse clarify/correct what you mean in the portion " ANSWER: It can be run out lower into the lower" The sill, the metal portion of the bed below the tailgate but above the bumprer mounting. The neck on that Maverick can be bent slightly so that it comes out in the sill rather than have to be filled thru the bed. It will allow the gas to flow down into the tank like it needs to.
ALSO -
Do you mean that 2 sizes of tank were available in the 77-82 Chevy Van and the 22 gal. is the smaller of the two? ANSWER: yest there was two tanks available the smaller 21 or 22 Gallon and a larger 30 plus gallon tank which is to wide to fit between the rails.
__________________
RMF
I'm in shape.
Round is a shape.
Old Jun 28, 2003 | 06:52 AM
jniolon's Avatar
jniolon
old and in the way
GAS Tanks
Donald,
I'm sure you know about the mustang tank...like I did
have a look on www.gastanks.com... lots of tanks with dimensions and pictures.. you might find another candidate there
john
Old Jun 28, 2003 | 08:35 AM
tacson's Avatar
tacson
GAS Tanks
John I do know about the Mustang tank. What I was looking for for my 55' was a tank with a neck that allowed you to put a filler either out to your fender or to the lower sill. I did not want to cut in my my bed wood for a filler. I thought someone else might want the same thing... I bought a filler door from Mid50's. The curved hagan door that will mount in the fender. My truck is about 3 weeks from being complete. I hope to take it to Shades of the Past or Chimney Rock. 88 EFI 5.0 with AOD, 87 Crown Front end and 67 Fairlane 8" with a 3.25 ratio, Old Air Climate control. I anticipate it being nice when complete. John I will probably be down your way to the one of the Birmingham swap meets. Thanks
Old Jun 28, 2003 | 08:54 PM
ferguson777
GAS Tanks
Tacson,
Thanks for the clarification. While I fully intend to go the rear mount, I wanted something that would hold more than 18 U.S. gallons....and I don't want the filler in the bed......
Later,
Old Jun 29, 2003 | 09:55 AM
truckfarmer's Avatar
truckfarmer
GAS Tanks
the 61-66 Econoline vans had a tank like the Mustang except it has the filler tube on the driver's side.
Old Jul 11, 2003 | 10:08 PM
tacson's Avatar
tacson
GAS Tanks
Can anyone tell me how to post a picture in my reply in this forum? Thanks
Old Jul 11, 2003 | 10:20 PM
mr4speedford's Avatar
mr4speedford
GAS Tanks
When you click the reply button the screen where you type and all the options are comes up, click the button in there that says IMG. You will then have to post the link(web address) for the picture. You can't post pics from computer or floppy disk, it either has to be in your gallery or on a photo host. Let me know if you need any more help. -4speed
Old Jul 12, 2003 | 09:13 AM
DS02F250's Avatar
DS02F250
GAS Tanks
Ah, thanks 4Speed. Never knew that and have been frustrated not being able to do so. Hey, how was the GoodGuys show???
-Daryl
Old Jul 12, 2003 | 10:36 AM
tacson's Avatar
tacson
GAS Tanks
4speed HELP???????????? I have uploaded pictures to my album and I can not even see them in my album. I have a gas tank in my truck that I would like to show everybody. WHat might I be doing wrong
Old Jul 12, 2003 | 12:46 PM
Kecky's Avatar
Kecky
GAS Tanks
Tacson, the main thing to keep in mind for posting pictures into your gallery is picture size. The host only allows resolution of no more than 320,000 bytes. Make sure your resolution is not too high. If you can't change it on your camera when you take to the photo you can resize the photo with this program.http://www.showyourphotos.com/downlo...zer%20Download I have used this and it works well. Courtesy of "Earl"
Hope this helps.
Kevin
Old Jul 13, 2003 | 01:40 AM
tacson's Avatar
tacson
GAS Tanks
Kecky,
Thanks for the help. Everyone look into my gallery/album and see the GAS tank install and let me know what you think. Thanks
Old Jul 13, 2003 | 06:21 AM
jniolon's Avatar
jniolon
old and in the way
GAS Tanks
Donald...
nice job on the install... is that the 22 gallon ?? it looks big !
john
Old Jul 13, 2003 | 08:21 AM
4tl8ford's Avatar
4tl8ford
GAS Tanks
Nice job on the Tank.
Can we get some more shots , like the filler neck detail, mounting etc?
