GAS Tanks
#61
#62
#63
your filler hose looks to be in side the bed at the area that it goes vertical I'm old so I could be wrong
#67
#68
am I skipping anything, Dan gave me the gas cap so I didn't get the sheet metal off the jag I made a pattern from cardboard of the cap mounting area did a lot of layout on the fender temp mounting it to the bed so on.
this is the under side of the fender
fuel filler in fender use a jag cap
I used a saber saw to cut the fender for the filler then used the drop piece for the mount I spaced it with a 7/8" strip of 18 gauge welded it up(I think it was 7/8 maybe 3/4)you can see the recess
#69
I cant find a pic of my filler hose/breather take my word it was a lot of work.
I got the filler hose from an online co that makes the hoses cant remember the name
made a holding bracket that supports the filler/breather hose that bolted to the fender bolts like a double nut thing
Jag fuel cap
Jag fuel cap
#71
In answer to another of your questions, my tank is mounted on the bottom of the frame, even has a 3/4 spacer between the tank and lower frame rail. It still is VERY close to the wood of the bed.
Reading Tacson's post he is talking about a maverick tank going out the back under the bed. Isn't a Maverick's tank the same as a Mustangs?
#72
my hoses are just below the wood in the bed my bed has a sub frame of wood also so I have an extra 3/4" over the truck frame
I don't know about maverick/mustang tank just read about them
as for tire clearance moving the tank as far to the rear helped I have a good size bracket in back of the tire
projectmoneypit
29
10-11-2023 02:47 PM
bellssn690
05-27-2016 06:56 PM
kevin-11
52
03-22-2016 12:40 AM
