Vacuum Leak
Old 01-20-2014, 08:54 PM
tatonka's Avatar
tatonka
tatonka is offline
Vacuum Leak
Guys, I have a 91 ford f150 5.0 engine. engine idles about
1500 rpm. I think I found a vacuum leak at the diverter valve
behind the intake. would this cause the engine to idle high?
Old 01-21-2014, 02:43 PM
White Max's Avatar
White Max
White Max is offline
Yes, a vacuum leak can cause a high idle.
Old 01-21-2014, 06:08 PM
tatonka's Avatar
tatonka
tatonka is offline
that looks like a major job to change. if I take the smog pump off will that
fix the vacuum leak coming from the air diverter valve?
Old 01-21-2014, 06:14 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,194 Likes on 943 Posts
No it will not.
RV_Tech
11-04-2016 02:19 PM
75N
03-17-2015 11:42 PM
dharte
11-01-2014 06:28 PM
inspector1
02-19-2008 07:26 PM
Quick Reply: Vacuum Leak
