time for new radiator, need help
Old Jan 22, 2014 | 11:00 AM
nikmish's Avatar
nikmish
This is awesome, thank you very much everyone! (special thank you to you Franklin2 for going through trouble and doing the research like that!!!).
My local O'reilly sells aluminum with plastic and I heard that they are not good.
I think I will go with Spectra Premium CU558 and I will check local shops first.
Thanks again!
Old Jan 22, 2014 | 05:44 PM
bill06447's Avatar
bill06447
The aluminum ones dissipate heat better so you can get away with a smaller, lighter one for the same cooling capacity, but the brass ones usually last the life of the truck and are rebuildable/cleanable. ~Bill
Old Jan 22, 2014 | 05:55 PM
nikmish's Avatar
nikmish
Will this fit?
http://www.ebay.com/itm/131041940881?_trksid=p2055120.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 22, 2014 | 06:09 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yes, but it appears to be the narrower of the 2 options. You would need a different upper hose, and the shroud would not work.
You need the ~27" wide version to be a direct fit. The ~21" version was mostly used for non-A/C applications.
Old Jan 22, 2014 | 06:16 PM
nikmish's Avatar
nikmish
great, thank you VERY MUCH!
Old Jan 22, 2014 | 06:31 PM
Rogue_Wulff
That is not a direct fit replacement, but can be made to work.
Nice looking unit though.
wyoranch
15
Sep 1, 2013 10:16 PM
dennisb56
Mar 20, 2011 05:36 PM
deyomatic
Apr 29, 2009 08:29 AM
mattsf-100
Mar 24, 2007 02:36 AM
55forder
25
Mar 17, 2005 11:46 AM
