X-Fer case lock lamp ???
Old Jan 17, 2014 | 04:16 PM
DaytonaTunnel's Avatar
DaytonaTunnel
Anyone have, or even seen this http://www.ebay.com/itm/1974-1979-NOS-FORD-F100-F150-F250-4x4-TRANSFER-CASE-LOCK-LIGHT-BLUE-LAMP-/310842795791?pt=Motors_Car_Truck_Parts_Accessories&hash=item485faca70f&vxp=mtr ?
Is it factory ? I've never seen it before.....
Old Jan 17, 2014 | 04:52 PM
79FordBlake's Avatar
79FordBlake
Yep its factory. Usually only found on full-time 4x4 trucks and broncos. My 78 full-time 4x4 bronco has it and still works. It shows you that the differential in the transfer case is locked together when in 4 low lock and 4 high lock.
Old Jan 17, 2014 | 06:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by DaytonaTunnel
Anyone have, or even seen this 1974 1979 Ford F100 F150 F250 4x4 Transfer Case Lock Light Blue Lamp | eBay ?
Yeah, I've got one in my "parts department". Used on full time 4WD like 79FordBlake said.
Old Jan 17, 2014 | 09:23 PM
DaytonaTunnel
VERY cool, any of uze guyz have a pic of one installed....just curious what it looks like and where it goes.
Old Jan 17, 2014 | 09:42 PM
79FordBlake
Here is the one in my 78 Bronco. The flash on my camera was to bright so you can't tell that the light was on saying LOCK.
Old Jan 17, 2014 | 10:17 PM
DaytonaTunnel
That's cool, thanks !!!!
Old Jan 18, 2014 | 11:37 AM
willmunny79's Avatar
willmunny79
My 1979 f150 has this light. I assumed it was not full time 4wd because. I have to manually lock in my hubs and select 4h or 4l on the transfer case. I am wrong?
Old Jan 18, 2014 | 11:51 AM
spikinfool05's Avatar
spikinfool05
i have two of them i am gonna use them for the lockers in the axles.
Old Jan 18, 2014 | 11:59 AM
DaytonaTunnel
Cool idea spikinfool05. Did all NP203 equipped trucks have this ?
Old Jan 18, 2014 | 12:05 PM
79FordBlake
Maybe transfer case was changed? The NP203 has a differential in it while the NP205 does not.
When the NP203 is in low lock or high lock a switch near back of transfer case is energized making the LOCK light come on. Letting you know differential is locked together.
When in just low or high the front and rear axle are able to rotate at different speeds.
Old Jan 18, 2014 | 12:37 PM
willmunny79
That is exactly how it works, hmmmm,
I assumed it was the stock set up. I am happy with it whatever the case may be. I have a good running truck on the street and a beast in 4l when I need it
Bad 674x4
Mar 4, 2013 08:17 AM
Randomtasker
Jan 29, 2008 10:48 PM
funnyboy
Jan 31, 2005 08:00 PM
supercab4x4dually
Dec 8, 2004 10:38 PM
tothfngclw
1978 - 1996 Big Bronco
Sep 11, 2002 02:12 PM
