Drum to Disc conversion?
Old Jan 17, 2014 | 08:45 AM
tom from mass's Avatar
tom from mass
I have a "97 F-250 7.3L. I tow a 20 ft. boat weighs around 4000 lbs. I removed the surge drum brakes from the trailer cuz the saltwater ate em up. In MA law states that trailer brakes are required on trailers weighing 10,000 lbs. or more.
Has any one done the conversion to disk brakes on the rear. Is it worth the expense? Does it give the truck better stopping power over the factory installed drum brakes?
Old Jan 17, 2014 | 09:34 AM
mrrish79's Avatar
mrrish79
Great question I'd like to know as well as I'm going to be doing my rear brakes in the spring. I have read something about this topic during a search one time I believe.
Old Jan 17, 2014 | 10:34 AM
broncoderek's Avatar
broncoderek
I've read here (from Brad?) and elsewhere that a PROPERLY ADJUSTED AND MAINTAINED drum brake system is perfectly fine and just not worth the expense and work to convert to drums.
I agree with all that myself.
Old Jan 17, 2014 | 10:43 AM
rla2005's Avatar
rla2005
This question gets asked here all the time. As others have indicated a properly adjusted and working set of rear drum brakes work just as well as a disc brake setup.
If you feel the need to empty your wallet take a look at this for reference:
10.25" Ford Rear Disc Brake Conversion
https://www.4wdfactory.com/store/pro...Conversion-Kit
Disc Brake Adapters - RuffStuff Specialties
Old Jan 17, 2014 | 10:58 AM
Phy's Avatar
Phy
There are a lot of threads of rear disc conversions. Rear drums in working order & adjusted properly work quite well. Discs cool better and don't fade as easily, but unless you're hauling heavy & driving mountain passes a lot, it probably wouldn't be worth the trouble & expense.
Old Jan 17, 2014 | 11:00 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
wow that's really high weight before trailer brakes are required in Mass! yikes.here in Maine,it's just over 3k lbs.
Tom,forget that idea.if you want to truly increase your trucks stopping power.this is how it's done right here:
Hydroboost Brakes
(i recommend repairing the trailer brakes too though,if you can afford it.)
Old Jan 17, 2014 | 12:16 PM
Nothing Special's Avatar
Nothing Special
A quick Google search confirmed that in MA the limit is 10K, but also that trailers that heavy need air or electric brakes. In MN (as in most states) brakes are required above 3K. MN also requires breakaway brakes on trailers over 6K. So even though MA is pretty lenient, if you tow out-of-state it might make things easier if you fix the trailer brakes.
I haven't done much trailer brake maintenance, but I'd guess that electric brakes would be simpler to service than surge brakes. They definitely work better (assuming you have a good brake controller).
freebird63
Oct 21, 2013 01:31 PM
Munky
1997 - 2003 F150
Feb 1, 2007 09:27 AM
bassproguy07
Dec 14, 2005 10:12 AM
White_Knight
Nov 23, 2003 03:17 PM
