2005 explorer radiator replace easy or hard?
Old Jan 15, 2014 | 06:26 AM
ascheperle's Avatar
ascheperle
How many of you have replaced the radiator in a 05 explorer w/v6? Local shop wants $450 and dealer wants $625. They both say the labor is 3.5 hrs and a lift is required for replacement from the bottom.
It doesn't look hard to do, but I could see how it would take some time. With just a quick look at it, I see 4 hoses (3 large and 1 overflow), 4 bolts on shroud, 4 bolts on main bracket, 4 bolts to remove rad. from bracket. There may be other hidden stuff?? Like the one bolt that you have to remove the engine to get to, LOL.
I can get lifetime warranty rad. for $150 + $$ for anti-freeze. Figure I could save almost $280.
Thanks guys.
Old Jan 15, 2014 | 07:09 PM
sccamper's Avatar
sccamper
Those radiators are tough. It has to come out the bottom. I think you have to dislodge the a/c condenser from the front of the rad. The rad gets hung on the a/c lines as its coming out. PITA. Its been awhile since Ive done one and I had a lift.
Old Jan 20, 2014 | 11:51 PM
S360S's Avatar
S360S
They are not that bad. you could pay to have the a/c evacuated and remove the condenser with the radiator, speeds things up a bit.
Old Jan 20, 2014 | 11:57 PM
S360S's Avatar
S360S
also i do not remember ever removing one from the bottom and have done several 02-05 and 06-up
Old Jan 23, 2014 | 09:05 AM
projectnitemare's Avatar
projectnitemare
I'll call bull*****. I replaced my rad from the top. It's a pain but it can be done. The big deal is the rad, trans cooler and a/c condenser are all bolted together and are supposed to be R&Red together. If you have a set of rachet box end wrenches just unbolt the rad from them and pull it out the top.
Old Jan 23, 2014 | 03:37 PM
70f100longbed's Avatar
70f100longbed
It's easiest to pull the radiator with the condenser and trans cooler as one piece from the top. 06+ can come out the bottom without pulling the condenser or trans cooler.
Old Jan 25, 2014 | 01:51 PM
ascheperle's Avatar
ascheperle
Thanks for all the replys. I ended up letting my buddies body shop do it. I almost forgot that they replaced the rad after I lost a game of chicken with a deer in 2006. The company that he gets them from does offer a lifetime warranty, but he will need to find the invoice. If not, he will give me the rad for his cost and cut a deal for his shop guys labor.
He said it came out the top and was a PITA, just like you guys said.
Old Jan 27, 2014 | 03:23 AM
oneowner83's Avatar
oneowner83
Auto Zone has lifetime warranty as well
makuloco2000
Jun 15, 2021 07:16 AM
havns3
Mar 2, 2013 10:21 PM
bmbrdfrt
Jun 24, 2011 10:37 AM
vacuumbed
Jun 17, 2009 05:37 AM
Ford79
Apr 28, 2007 08:22 AM
