Dad's Air Cleaner
Though on the other hand I've heard of sports cars being sluggish in the desert during the day and come to life at night. Though everything in that example is an extreme.
Very interesting to my feeble mind though. Always learning something
- You can't trust anyone with an accent like that.
- The were testing a fuel injected engine which adjusts the air/fuel ratio for the air temp. Our carbs don't adjust and that's exactly why the factory tried to keep the inlet air temp to the carb at a set value.
- They were testing a vehicle with an intercooler, which cooled the air and kept the inlet air temp to the engine constant regardless of the air temp going into the cleaner. So, except for the minor change in the last test, the intercooler wasn't allowing the temp change to make it through. In the case of our trucks there is no intercooler and inlet air temps changes will be seen at the engine.
Mavsprint - That's what I think I'll do - turn the thing upside down. And, there were two different pieces that went on the radiator support. Here they are:
Oh well..maybe his name really is "John"...anyway, I didn't post the video, so, go ahead on..
(back to my afternoon nap)..
Kinda funny - I read a book called Charlie The Ranch Dog to my grand kids, and he's always taking a nap. But it is John, that really isn't John, and not Charlie that naps in this case.
1- cold air Induction. - as you know, the colder the air the higher the density (at sea level, altitude brings its own fun) with the objective to avoid hot under bonnet air temps. If both snorkels have the blocker / bypass valves working to grab warm air when needed then it's all good.
2- ram air effect. - taking advantage of a high pressure zone created by the vehicle travelling at speed to provide a level of forced induction overcoming vacuum in the intake tract. OEM's use 2 positions, at the base of the windshield (think cowl scoops and the Pontiac grabber scoop) and at the grille/ front bumper region. These bullnoses have a huge "bucket" behind the grille that would provide quite a high pressure zone, given the brick-like aerodynamics they posess.
Both events are to achieve the same end, more air in to increase the volumetric efficiency of the engine. At speed you will use less throttle input to create the same effort. My older Merc has a 4.2 L V8 with 2 large ram/cold air snorkels similar to what you are proposing coming off the rad support from the factory. Mercedes certainly don't do things without the engineering to ensure they are viable.
As for there being two places the OEM's use to get ram air, I beg to differ - my '69 Super Bee is a case in point. Here's a picture of a similar one, which used hood-mounted scoops called, oddly enough, Ramcharger:
But, in reality the scoops weren't placed at a high pressure area so they weren't all that effective for ram air. However, they were effective in getting cold air to the carb as they didn't have long runners but dumped right into the carb.
On the other hand, you do have a valid point about our trucks - they are worse than a brick in that they have the grill set back from the leading edge. So that means the area ahead of the radiator support should be a high pressure area.
BTW- great classic muscle there, have you upgraded the handling at all? My limited experience with classic American muscle of that era is that they can posess the handling dynamics of a water balloon with a rocket strapped to it
But, it does have cold air induction. In fact, the handle on the cable inside that opens the doors to the scoops reads Cold Air and there's a light on the dash that reads the same. That was back before they worried about leaning out the AFR to get emissions down and economy up, so there was no heat to the un-silenced air cleaner. Boy, did they sound GOOD at full throttle!
Here's a shot of the engine with the air cleaner:
And here's how the passenger's side snorkel clears the valve cover by about 1/2":
Unfortunately, the driver's side doesn't clear with the HO snorkel:
But, with the standard-style snorkel it does clear:
And, there's the problem of the angle the HO snorkel makes as it leaves the air cleaner. Using two HO snorkels doesn't work if you center the air cleaner with the tabs on the carb. Note where the snorkels are with reference to the valve covers:
But, adding one standard style snorkel helps a lot:
Bottom Line: I'm going to use two standard snorkels, which will clear the valve covers better and will give the proper angles.
In my mind's eye I'm seeing way too much black. Its sorta reminding me of 1966 all over again - http://en.wikipedia.org/wiki/Paint_It_Black. So, maybe the valve covers and air cleaner do need to be blue. But, I think the first step is to mock it up further and see what the brackets do to the look. And then, once I've seen BLACK I think I see another rattle-can giving up its life to coat an air cleaner and snorkels plus both valve covers in OFB.
And I agree with bruno; I painted the base of my own air cleaner Ford Blue to match the Ford Blue engine block and distributor cap and wires, but kept both of the snorkels black. I am still working on the driver's side plastic scoop that bolt to the radiator core support for the ducting to connect to.
Gary, are you going to have an underhood toolbox in the engine bay? I have one in mine, and the way the stock H.O. snorkel is lined up asymmetrical to the passenger's side works well to clear the toolbox. With the longer standard snorkel, I don't think it will clear. You also have to make sure it will clear the A/C compressor, if equipped. 1980 - 1982 used a different compressor and a different mounting bracket, and therefore is in a different position than the 1983 - 1986 models.
I also had to reverse the PCV valve and the oil breather cap locations on the valve covers when I switched to the H.O. air cleaner assembly. The stock location of the PCV valve was on the rear of passenger's side valve cover, and the oil breather cap was on the front of the driver's side valve cover. This arrangement worked fine with the stock air cleaner, but the H.O. air cleaner has the oil breather cap filter hole much closer on the passenger's side. Plus, if I left the oil breather cap on the front driver's side snorkel, I couldn't get to it to unscrew the cap because the snorkel runs right above it and it is too close to the A/C compressor. It wouldn't leave enough room to get your hand or an oil bottle there.
Last thing: From your pictures, it looks like you have a push-on oil breather cap. If that is the case, I would STRONGLY recommend you replace the valve covers with the screw-in type holes. I replaced a set of really nice aluminum "302 Powered By Ford" black wrinkle valve covers (with cheaper GM-style push on style breather cap holes) because the oil cap was constantly falling out!
