Receiver pin
Old Jan 13, 2014 | 05:05 PM
Skip8604's Avatar
Skip8604
Receiver pin
Can someone help me out with what size is the pin that goes into the class V receiver and ball mount to lock it in? Think it's 5/8 but I'm not sure. Thanks
Old Jan 13, 2014 | 05:10 PM
SavageNFS's Avatar
SavageNFS
Mine is 5/8"
Old Jan 13, 2014 | 05:15 PM
Skip8604's Avatar
Skip8604
Ok I'll order one up. Didn't have that size at my Tractor supply so I couldn't check it out. Thank you
Old Jan 13, 2014 | 06:04 PM
720Deere's Avatar
720Deere
A regular hitch pin 5/8" x 4" is the best bet. I hate those stupid little bent pins that come with hitches. Wagon hitch pins like those found at Tractor Supply are usually stronger than a regular receiver pin also.
Old Jan 13, 2014 | 07:23 PM
69cj's Avatar
69cj
If the hitch is working properly that stupid little bent pin should not see any real stress on it.
Old Jan 13, 2014 | 07:40 PM
720Deere's Avatar
720Deere
I was referring to the bent nature of the end of the pin rather than having a head or a handle on the end. It isn't about stress bending the pin, it is about the convenience of actually having something to get a hold on to remove the pin.
Old Jan 13, 2014 | 07:51 PM
Iowa Ford's Avatar
Iowa Ford
X 2 Matt
Also drill out the hole in the new pin and use a nice big retainer clip that u can put in and out easily even if it is dark or cold Etc.
Iowa
Old Jan 13, 2014 | 08:11 PM
Bobbykjl's Avatar
Bobbykjl
Mine is 5/8" by 4"
It uses the standard hitch pin clip but doesn't have the hole in the pin. The end of the pin has a groove about a 1/4" from the end and the clip goes around that. First time I've seen that.
That hitch reducer is a pain in the neck. My hitch is 2" and I have to fiddle with that reducer to get the hole lined up.
Old Jan 13, 2014 | 08:36 PM
Iowa Ford's Avatar
Iowa Ford
Originally Posted by Bobbykjl
Mine is 5/8" by 4"
Bobbykjl , You can buy the bigger hitch to go in the receiver and toss the adaptor under the bench !!
Tim.
chibulls
Nov 1, 2022 07:57 AM
bertturtle
May 15, 2018 11:01 PM
Tractionless
All Things Towing
Oct 20, 2016 09:03 AM
King_Kong_01
6.7L Power Stroke Diesel
39
Feb 11, 2014 09:27 AM
kappysworld
All Things Towing
Jun 22, 2008 10:54 PM
