gauge cluster hook up
Old Jan 13, 2014 | 02:26 PM
buzzy613's Avatar
buzzy613
I just bought a 1977 f150 and I was wondering if there was a diagram for the gauge hook up and if there was a way to tell the gauge backs if they were plastic or the paper back
Old Jan 13, 2014 | 02:50 PM
fmc400's Avatar
fmc400
MSEE
Are you asking for the pin-out of the rear connector? 1976 is easily available on Fordification, but 1977 is not. However, the cluster printed circuit is simple enough that you can ohm it out with a meter to understand what trace leads where. There's a significant distinction between gauges and lights.
The original cluster was made from composite material that crumbles easily. Look for broken our opened-out bulb mounts. Anything that resembles a 1976 and earlier engineering number would be composite material. Plastic clusters were only available as service replacements, later-model Econolines, or modern aftermarket versions (some of which are nearly translucent).
Old Jan 13, 2014 | 02:54 PM
buzzy613's Avatar
buzzy613
Honestly I'm not sure I thought there was a lay out for the wiring none of the gauges work and I wanted to pull the cluster but I searched and really didn't get the full explanation. It just an project that I want to get done also did they make a factory half ton high boy?
Old Jan 13, 2014 | 06:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, there never has been an F100/150 "highboy".
As for the cluster. First do basic troubleshooting, check the fuses with a voltmeter, check both sides of the fuse.
Is your cluster completely not working? Do any of the gauges work? What about the lights, do they work.
Do you have an ammeter or an idiot light for the alternator, the wiring is different.
If nothing works first make sure the wiring harness is plugged into the back of the cluster.
On the back of the cluster there is an ICVR (instrument cluster voltage regulator) If none of your gauges work (don't include the ammeter, those things rarely work anyway) this could be the problem. The gauges run on ~5.5V not 12V.
Old Jan 13, 2014 | 09:05 PM
buzzy613's Avatar
buzzy613
The alternator fuel and water temp do not work and I don't believe the speedometer works either, the lights work. I laid on the floor and looked up and seen that the alternator gauge was either unplugged or was I just looking at the back to hold it to the nano board. Also can some one tell me how to carefully remove the cluster?
Old Jan 14, 2014 | 12:01 AM
crazy96863's Avatar
crazy96863
Remove bezel. Unscrew cluster, pull out slightly, remove speedo cable and wire harness plug. Remove the cluster the rest of the way.
I replaced my circuit board with one from a late 80's/early 90's van. (Not sure when they changed it but this works great; same cluster).
Old Jan 14, 2014 | 07:01 AM
buzzy613's Avatar
buzzy613
Alright thanks I'll take a look and start working on it when I get home
49f2owner
Jul 7, 2014 10:33 PM
Gembone
17
Aug 1, 2013 05:55 PM
rjohnson_15
Dec 25, 2012 09:42 PM
Vin Man
Electrical Systems/Wiring
Nov 29, 2012 10:05 PM
nojeffgordon
Jun 7, 2004 10:07 PM
