Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Autostart install with door lock problems
Old Jan 12, 2014 | 09:46 PM
devon123's Avatar
devon123
Hey guys, I just installed a remote start in my 08 f350 and everything is working but the door locks. I have talked to their tech support and they had me replace the module which did not solve the problem. Has anyone on here put one in or had a similar problem? I have checked and rechecked all my wiring and cannot figure out what is going on. All my connections are soldered and should not be a problem. Any help would be appreciated.
Old Jan 13, 2014 | 07:35 AM
ATV PRO #11's Avatar
ATV PRO #11
If installed correctly, I know those things are very hard to do, I would think it's a programming issue. It may be in "Valet Mode". What type of command start is it?
Compustar?
Old Jan 13, 2014 | 06:08 PM
devon123's Avatar
devon123
It is an autostart with a 2 way transmitter. I called their tech line and they said it was the module. Changed that and still have the same problem. I have gone through all the programming and I can't see where I could change anything but I guess it is trial and error now.
Old Jan 30, 2014 | 09:25 PM
radmacks's Avatar
radmacks
With those who have to set whether it is a negative or positive pulse. Are you still having issues? If so please post the model and color wire you are connected to. I'm no pro but my brother is a pro installer and fellow Ford lover and we'll do what we can to get it right.
Old Jan 30, 2014 | 10:12 PM
devon123's Avatar
devon123
It is an Autostart 6870tw-fm. The wire coming out of the module for the door lock is brown and I have wired it into the blue and light green wire behind the driver kick panel.
Old Jan 30, 2014 | 10:31 PM
radmacks's Avatar
radmacks
That truck is type B and you need too hook up both wires;
Autostart Brown big harness to Kick panel truck Blue/Light Green Lock
Autostart Green big harness to kick panel truck Yellow/PURPLE Unlock
There is also a jumper if it doesn't work you might have to switch the jumper. (back of unit)
If this doesn't help let me know and I can ask my brother.
Old Jan 31, 2014 | 12:35 PM
devon123's Avatar
devon123
So I checked the wiring and it is all proper. I will check the output and see if it is on positive because I believe the lock is supposed to be a negative output. Thanks for the help
Old Feb 3, 2014 | 08:43 PM
devon123's Avatar
devon123
We'll the wiring is correct but I cannot find the jumper you are talking about. There is one for the park lights and one for the tach. If you could talk to your brother that would be great!
Old Feb 3, 2014 | 09:57 PM
radmacks's Avatar
radmacks
In the manual when looking from the back its on the left side. Did you program the unit ? Ill ask him if he has any suggestions
Old Feb 5, 2014 | 03:30 PM
devon123's Avatar
devon123
I did program it but I may have missed something. I could not find the jumper for the door locks but maybe it is listed wrong in the manual. Thanks for all the help.
CWO-06250
Apr 1, 2008 11:11 AM
Strok'in
13
May 15, 2007 11:51 AM
athon1
Nov 9, 2006 11:58 AM
scarface78
Nov 23, 2005 10:34 PM
Gaetan
Aerostar
Mar 15, 2003 12:07 AM
