I run motorcraft 5w20 in my truck. Either the synthetic blend or the full synthetic. Changed at 5-6K intervals. ( I do it bit early since I work in public safety)
how you liking your 6.2. have you pulled anything yet ?
Very happy with it. Pulled 7000lbs (enclosed tandem) over 5000 miles (TX to San Jose, CA and back then to points around TX). Pulled like a champ.
Got 11 mpg pulling @ 70 mph. I locked out 6th and had a ball. I did pull for the first few hundred miles in 6th but the mileage was a bit less at 10.5 mpg.
That's the motor I'd get if I were buying a new truck. Sad that they're not keeping it around
