valve covers
Old Jan 11, 2014 | 12:47 PM
yme450's Avatar
yme450
valve covers
I started to change my glowplugs just to find out they were good. i have a realy hard time starting it when cold.when plug in starts right up.new batterys,new gpr,and now new glowplugs.thanks Riffraff. well i found my valve cover are rotted out. did anyone find there valve covers rotted to the point were there leaking to. now i need to find valve covers.not a good day for me.
Old Jan 11, 2014 | 01:13 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
We would strongly suggest getting only Motorcraft valve cover gaskets. We have seen a lot of trouble from Dorman, so I would save yourself the trouble down the road. Here is the Ford part number and what price you can try to get them to match.
Valve Cover Gasket 99-03 - Riffraff Diesel Performance
Old Jan 11, 2014 | 01:19 PM
Ponyboychris's Avatar
Ponyboychris
Are you talking about the metal valve cover or the gasket?
Old Jan 11, 2014 | 02:55 PM
yme450's Avatar
yme450
The metal valve cover is what went.now i need new ones.
Old Jan 11, 2014 | 02:57 PM
yme450's Avatar
yme450
RiffRaff can you get me a price on the right and left metal valve covers 2001 7.3
Old Jan 11, 2014 | 03:12 PM
Riffraff Diesel
PREMIUM SPONSOR
No problem. Might even have a clean used set I can give you for shipping if you want.
Old Jan 11, 2014 | 03:27 PM
yme450's Avatar
yme450
Thank you.
that Sounds like a deal to me when can i call you.
Old Jan 11, 2014 | 03:59 PM
Ponyboychris
This dude is pretty good to us.
Old Jan 11, 2014 | 04:04 PM
cj45lc's Avatar
cj45lc
+1 to that
Old Jan 11, 2014 | 07:44 PM
Christof13T's Avatar
Christof13T
He would be even better if he would come visit us in Texas!
Old Feb 9, 2014 | 04:18 PM
massmtnbikn's Avatar
massmtnbikn
What goes wrong w/ Dorman? I just changes out all my glow plugs and opted to replace the gaskets w/ Dorman. With the UVCH issues, the dorman seems to be the right way to go. (I did the 0.50cent fix a few years ago after one of mine worked loose)
Old Feb 9, 2014 | 05:13 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Its been rumored that some have been found to be wired wrong, as in changing the firing order.
Old Feb 9, 2014 | 07:37 PM
Riffraff Diesel
PREMIUM SPONSOR
Well, let's just say they aren't going to China for the quality
Usually we run into wiring issues, burnt pins, loose pins etc.
Old Feb 9, 2014 | 09:16 PM
ebbnflow's Avatar
ebbnflow
I just did my passenger side harness with a dorman because of a burnt glow plug pin in the original oem gasket. The one I got from dorman was a 1 piece gasket and internal wiring harness. There was no connector on the inside of the gasket. Was yours like this or a 2 piece?
Old Feb 10, 2014 | 10:08 AM
massmtnbikn
No, Dormans is a one peice, which I think is a good benefit over the 2-piece Motorcraft design. I did 'adjust' some of its connectors for a tighter fit to GPs and Injectors. (Probably more personal preference tho)
The kit comes with the truck side wiring harness pigtail which is nice to keep for testing.
Akhnot
May 2, 2015 07:17 PM
53OlderThanMe
Sep 8, 2008 10:00 PM
stegmst
Jul 19, 2005 12:03 AM
mrmrschris
Jul 22, 2003 11:38 AM
