Low ECT Causing Poor Performance?
Old Jan 11, 2014 | 11:50 AM
PowerStruck2004's Avatar
PowerStruck2004
This is the first winter that I have had my rig. The truck was down for several months in the fall while I rebuild the turbo for a turbine seal oil leak(Thanks BenchWrench for the tutorial), so I never had a chance to see the drop in operating temperature as it got colder. After get it back on the road mid-December, it seemed to be very sluggish and the ECT never got above 160*. After sliding a sheet of cardboard between the radiator and the condenser, it finally got up to about 175* and seemed to run better. Does this ECM have a open/closed looped profile like gassers? I thought I did something wrong with the turbo rebuild but it seems to be an ECT-related problem. BTW, the poor performance was that the engine would stop building RPM around 2500 RPM and just hang there until I let off the throttle on acceleration.
Old Jan 11, 2014 | 02:43 PM
BLADE35's Avatar
BLADE35
You May have a Small Boost Leak these turbo can be a PIA to seal sometimes or a CAC Boot Seal issue
Yes Running that Cold will Cause Problems LOTS if let go long enough But your Issue Not being able to go Over 2500rpm is more then Just running Cold ECT
Turbo is High up on List of possible causes
Start up Truck Cold and then Feel around ALL Exhaust Joints FAST AT Idle some guys will even hang a string on stick to see if it Blows around at the Joints
Poor MPG and will Clog all Sensors up and gum up EGR Valve Also wont Combust properly You Need a thermostat Get one from FORD they seem to last better All the Aftermarkeyt ones usually only make 1 Summer then Run cold that next winter
Need to Make sure its Not a Bad Sensor by compare ECT & EOT & TFT after 12 hour cold soak compare those temps upon STartup they should be SAME or within 1-2*f
You mention turbo was Off so What PSI BOOST do you see WOT
Would Also be a Good Idea to Clean EGR Valve and MAP Sensor/tube
Did truck have Plenty Power before you rebuild Turbo?? Just suffered smoke???
Old Jan 26, 2014 | 12:01 PM
PowerStruck2004
Everything seem good on the turbo connections and wiring. It just seems that it comes alive once it hits about 180F. It may be slightly off subject, but the upper radiator hose is always soft, even after the engine get fairly warm. Besides pulling the thermostat, is there any way to tell if the thermostat is hung open or is the soft upper hose just the way it is?
Old Jan 26, 2014 | 12:42 PM
King-bRanch's Avatar
King-bRanch
No but judging from your post u definitely need 1 & go OEM on that as Blade stated, the Hose will actually get softer as temp increases & most uppers dont have a spring inside as thats pushing back to radiator, the bottom being suction side should always have a spring & be firm feeling....
A new Stat is just good Insurance as truck is designed to running appx 190 ECT
Old Jan 26, 2014 | 01:56 PM
PowerStruck2004
What I probably should have said it that the hose doesn't feel like there is any pressure in it like all the gassers I've worked on. Back in the day, the way to tell if the thermostat was open or closed was to squeeze the upper radiator hose. This rig stays soft at all times, hot or cold. Since I'm the newest owner, I should assume that the thermostat is old. Cheap insurance is right.
Old Mar 6, 2014 | 04:51 PM
PowerStruck2004
Update: I replaced the thermostat about a month ago and the engine coming up to temperature 190F after idling only about 10 minutes even in 10F. Runs as strong as I have every felt it. The exhaust backpressure sensor on this year turns a 5 minute job into a 30+ minute job.
Old Mar 6, 2014 | 05:14 PM
69cj's Avatar
69cj
These engines don't need 10 min. idle time, in fact it's not really good for them. Couple minutes and then drive normal. No lead foot and they'll be happy.
Old Mar 7, 2014 | 01:52 AM
BLADE35's Avatar
BLADE35
SO your saying that with a Cold truck you can Start it up and in ONLY 10 minutes the ECT will be at 190*f
IDK if my truck will heat up that fast in July with 90*-100*+ ambient temps
Old Mar 7, 2014 | 02:46 AM
Yahiko's Avatar
Yahiko
I can see that in 10 minutes. @ 45ºF but at 10ºF it would take longer
and high idle would help. When it cold out I only sit and idle till I reach 75º~100º
running on high idle. But that is only a few minutes.
Sean
Jmoen7
Apr 13, 2016 06:42 PM
wicks302
Nov 10, 2012 04:42 PM
Baddfx4
Jan 23, 2010 09:04 PM
Brian460
Dec 21, 2004 06:38 PM
Spooky
Dec 2, 2004 01:44 AM
