Super Cab Question
Old Jan 10, 2014 | 10:25 PM
SuperDuty93's Avatar
SuperDuty93
Super Cab Question
From the factory are the mounting point for either a bench or the jump seats in the floor? The reason I ask is because a friend got a bench from a 80's ford and bolted it in the rear and now got the rear seat lift kit but the holes on the lift kit don't line up.....
Old Jan 10, 2014 | 10:57 PM
march's Avatar
march
Supercabs were set up with both jump and bench seat attachment points. Not sure if the 80's seats match up or not.
Old Jan 10, 2014 | 11:12 PM
SuperDuty93
That's whats odd.... Its a 75 SC 2wd, when he got it it had aftermarket jump seats in it and didn't have the latch on the pass side where the bench I believe would have locked into place when the seat wasn't folded down... The 80's seat seemingly fit, yet these brackets for the lift seat which are specifically made for dent side supercabs don't align with any of the holes in the floor. So it seems like when ordered from the factory there was a SC with holes for a bench only and other with holes for jump seats only. But to me that makes no sense and I think FORD would have had universal holes for whatever the buyer ordered to bolt in even after the SC arrived at the dealer if the buyer decided he wanted _____ as the rear option.
Old Jan 11, 2014 | 12:29 AM
brian1080's Avatar
brian1080
they have both holes. the extra holes in mine had rubber plugs in them.
Old Jan 11, 2014 | 01:05 AM
SuperDuty93
Same with his yet none of the holes still lined up. Anyone got pics of their mounting holes in the back seat?
Old Jan 11, 2014 | 01:16 AM
brian1080's Avatar
brian1080
Are you sure the lift kit is for the 70's trucks? You said the seat bolts in fine, just not the kit correct?
Old Jan 11, 2014 | 01:36 AM
SuperDuty93
Yea the directions say its for a 73-79.... something like that. I think they sent the wrong ones now. That's the only thing that makes any sense
Old Jan 11, 2014 | 01:48 AM
brian1080's Avatar
brian1080
I've never seen the lift kit, so I don't have much input on that. Maybe the brackets are upside down or on the wrong sides? If the seat bolts up fine, then it has to be the kit.
Old Jan 11, 2014 | 09:35 AM
march's Avatar
march
If I remember correctly there are three holes in a line along each side of the cab. The jump seats bolt into the two outer holes and the bench seat bolts to two adjecent holes. The seat belt attachment points for both set ups are also there.
It's dark and raining like a big dog right now or I'd go out and look under the cab to confirm. I'll try to take a look a little later.
Cntrylife
Sep 20, 2018 04:55 PM
Sabgut
May 20, 2017 05:09 PM
Myfreeford
Aug 25, 2014 04:00 PM
draven83
Jun 24, 2010 11:17 PM
custom87
Appearance & Dress-Up
May 9, 2006 08:30 PM
