Remove Cladding? Opinions Please..
Old Jan 15, 2014 | 06:06 PM
  #76
DSN46's Avatar
DSN46
Originally Posted by Apocalypse
That is one clean truck DSN. That's a huge point back towards the remove score I love that color too, very subtle
Thank you!
Old Jan 15, 2014 | 06:07 PM
  #77
DSN46's Avatar
DSN46
Originally Posted by USCG_PA
Very clean looking rig. I should be finally getting my fronts of in the next day or two, I will share pics once it is all cleaned up
Thanks! And please let us see it when you are done.
James
Old Jan 15, 2014 | 06:08 PM
  #78
DSN46's Avatar
DSN46
Originally Posted by 5.4T
I want to see the whole truck, did u change the grille?
Are you asking me or David?
James
Old Jan 15, 2014 | 07:18 PM
  #79
USCG_PA's Avatar
USCG_PA
So I went and took the front cladding off, my truck is now clean. Well actually by looking at the photos, my truck is not clean and is in need of a wash...
On a sad note, I found some body damage It was not under the trim, but looks like my door opened too far when the wind grabbed it from my hand, and the hinge hit and puckered out the knife edge. The worse part is that the paint has chipped there and is now gone Not sure what I am going to do to fix it. I am open to suggestions... FYI, the spot across from the damage is a water droplet.
Old Jan 15, 2014 | 07:30 PM
  #80
hav24wheel's Avatar
hav24wheel
Tap it back into place with a hammer with a rag over the head. Than touch up paint.
Old Jan 15, 2014 | 07:32 PM
  #81
USCG_PA's Avatar
USCG_PA
I was thinking just that, I even have a rubber mallet that should work, however, it is a little bit of a bummer. I did also post this on the "what did you do with your Ex today" thread, and I am sure I will hear the same suggestion there...
Thanks for the feedback
Old Jan 15, 2014 | 08:27 PM
  #82
DSN46's Avatar
DSN46
The truck looks great David!
One warning for you though... I have had a similar situation with a vehicle and learned a lesson from it. A small place like yours had been banged and bent up... the paint had chipped just a little like yours. I used a rubber mallet and popped it back into place, but... when I did, the surrounding paint for about 2 inches out got crack lines that eventually peeled off and I was left a huge spot that needed paint and even painted it stuck out like a sore thumb.
Lesson? Just touch up the small spot and leave well enough alone. OR take to a professional who actually knows the consequences of his actions from experience.
James
Old Jan 15, 2014 | 08:55 PM
  #83
Apocalypse's Avatar
Apocalypse
Honestly I would leave it alone too. Toss some clear nail polish or colored polish on it and try your best to not notice it
Sent from my 2014 BMW 730i with optional navigation and chrome package
Old Jan 15, 2014 | 09:11 PM
  #84
MalwareDRay's Avatar
MalwareDRay
For me it wouldn't be the "noticing". I would KNOW and that's just as bad. Maybe even worse!
Sent from my Galaxy Note 3 using IB AutoGroup
Old Jan 15, 2014 | 11:03 PM
  #85
EXv10's Avatar
EXv10
Originally Posted by icentropy
I know it doesn't work with cutout fender flares. I mean it'll work, but it requires trimming the areas that would be covered by the flares. The flares need to sit flush against the body.
So what's happening with the rear end?
Old Jan 15, 2014 | 11:57 PM
  #86
icentropy's Avatar
icentropy
So far so good but I haven't really driven it more than maybe ten miles. Need to go to town one of these days....
Old Jan 17, 2014 | 11:33 PM
  #87
MalwareDRay
How hard is it to remove the cladding?
My passenger side is damaged on the rear and I'm guessing that fixing up just the metal and ditching the cladding would be a cheaper option. Besides, the chrome piece would go away which definitely goes with my all - black theme
Old Jan 17, 2014 | 11:49 PM
  #88
USCG_PA's Avatar
USCG_PA
The cladding is very easy to remove. You just take off the fasteners around the wheel wells, and then pull up and away. The tape should give with little effort, however, some of it may remain on the truck, needing to be carefully removed from the quarter panels and doors. If you decide to do it, take your time and good luck!
Old Jan 17, 2014 | 11:51 PM
  #89
MalwareDRay
Is it ok to use goo gone?
I wonder if I'll find paint difference. Mine recently got painted.. hmmm
Old Jan 18, 2014 | 12:01 AM
  #90
USCG_PA's Avatar
USCG_PA
you may find some paint differences, but you will never know until you take a panel off. As for the left over tape, I just used warm soap and water and gently rubbed off that was left behind. Goo Gone, may work, but I have not tried it. I do know that WD40 will also loosen stuck on tape...
