4.9L L6 Manual Trans
Old Jan 10, 2014 | 05:35 AM
raven3's Avatar
raven3
Repowering 73 F250 with stock 390 cid with a 1989 4.9L (300) , L6.
What manual stock transmission for 2WD will directly bolt to the 300 without an adapter.
Any help would be appreciated.
Old Jan 10, 2014 | 08:47 AM
mefast's Avatar
mefast
A Mazda M5OD-R2 is the one that came on most F150s with the 4.9l. I think some F250s came with a ZF5. Is that correct everyone?
Old Jan 10, 2014 | 09:05 AM
raven3's Avatar
raven3
Noticed/Toyo Koyo 5 speed is listed as options for 4.9L
in addition to Borg-Warner T-18 4 speed & ZF 5 speed.
Where all these manual transmissions actually offered for 1989?
Old Jan 10, 2014 | 09:46 AM
paredneck33's Avatar
paredneck33
The NP 435 was also used for many years. Not quite sure as to what the last year was though.
Old Jan 10, 2014 | 06:20 PM
broke vet's Avatar
broke vet
IIRC Chilton and Haynes cite 1992 as the last year for a four-speed tranny in Ford trucks. I have tripped over numerous errors in both manuals, though, so the truth may be something else.
Old Jan 10, 2014 | 06:42 PM
88LX5.0H's Avatar
88LX5.0H
NP435, T18, M5OD, ZF6, and hell if you were stupid enough, you could even bolt up a Mustang T5 behind it. The straight 6 has an SBF pattern, so anything that went behind a 302 or 351 can bolt up to it.
EDIT: I meant ZF5, not 6.
Old Jan 11, 2014 | 07:19 AM
raven3's Avatar
raven3
Thank you for your response.
Will a C6 from a say 85 to 96 bolt directly to the 89 4.9L (300) engine?
Also, the stock 73 F250 trans is a C6 , bolted to an FE 390
Will this trans bolt directly to the 89 ,4.9L?
Old Jan 11, 2014 | 10:15 AM
88LX5.0H's Avatar
88LX5.0H
No the FE bolt pattern is not the same as the SBF pattern. But the 85-96(as long as it came behind an SBF) will bolt up. Just have to get the appropriate flex plate
Old Jan 11, 2014 | 02:02 PM
Diesel_Brad's Avatar
Diesel_Brad
I would be looking for a ZF5 from a 87-97 F250/F350 that had a 300, 302, or 351.
You get the OD and a pretty stout transmission.
The Mazda M5OD from the 87-96 F150/bronco will also work, but not nearly as strong
Old Jan 12, 2014 | 02:26 PM
mattri's Avatar
mattri
If your block is an 89 it may not have the threaded boss on the bell housing for the mechanical z-bar linkage that the earlier 4spds used.
DAJF150
Jan 11, 2006 07:45 PM
Katmandu
1978 - 1996 Big Bronco
18
Nov 2, 2005 07:45 PM
Brown89f150
May 8, 2004 04:32 PM
crossf-150
Jan 19, 2004 06:54 PM
gman1019
Jan 21, 2001 12:55 AM
