E4OD Shifts Smoother While Cold
Old Jan 9, 2014 | 05:50 PM
daddylee100's Avatar
daddylee100
My '92 F-350 (all info in sig) shifts exceptionally smooth like a brand new truck when its first started or really cold out. Don't get me wrong, it doesn't get rough when it warms up but it does get a little more noticeable. The fluid was changed about 1 year ago with new filter. Fluid is fine and smells fine. Is this something I should be concerned about. I am a worry wart about even the smallest thing so I thought I'd ask the best!!
truck has 98,xxx by the way...
Old Jan 9, 2014 | 06:02 PM
88LX5.0H's Avatar
88LX5.0H
Is it in all shifts or just the 2-3 and the 3-4?
I ask because when it warms up the computer allows the torque converter to lock up in 3rd and 4th gear. You may just be feeling the torque converter locking up, because Ford basically stacks 4th gear and lock up right on top of each other. I have a shift kit in mine and when it's cold it shifts the exact same for every gear, but when it warms up and shifts into 4th gear it's definitely the most firm because lock up coming in. Just a thought. You could also run the codes to see if you have any trans related ones.
Old Jan 9, 2014 | 06:38 PM
daddylee100
That might be what it is! I never thought about that.
Old Jan 10, 2014 | 01:03 PM
Island'r's Avatar
Island'r
Yeah its kinda annoying how they do that in the 3-4 shift...
Under normal acceleration mine is bad, but under moderately heavy acceleration sometimes its not too bad.
Kinda feels like it shifts twice and that the tranny is acting up, but that's just the way they are... You do get used to it eventually...
Old Jan 10, 2014 | 05:07 PM
88LX5.0H's Avatar
88LX5.0H
I think Ford has lock up come in so early is to keep the heat down. These E4OD's and even their later counterparts build up quite a bit of heat. Just look at the coolers they used.
The 98-02 Superdutys with the 4R100 has a good sized stacked plate cooler, and then the 5R110W has a cooler that's literally TWICE the size of the 4R's.
When you see a cooler like either of these, you know something is generating some heat.
Old Jan 10, 2014 | 05:50 PM
danr1's Avatar
danr1
Early model was capable of TCC lockup right after 2nd gear, later models lock up right after 3rd. Not sure exactly when though, seams about 91'ish?
TCC unlocks for shift OD, unlocks to soften the shift. It happens during the shift, unlocked|locked again but done in that split second takes to upshift, its nothing you'd feel happening. Just feel like single shift, no double hit kinda deal nothing like that, one shift into OD.
Early model would have done the same but for shift to 3rd gear too, unlock|lock for shift to 3rd and to OD but again nothing you'd feel it doing.
Talking normal acceleration speeds too, not taking off granny style but not like taking part in a drag race either just normal acceleration, increase in ground speed to point cause trans to upshift.
If its not operating like that than sounds like something may be amiss, if as bad as you make it sound? Find the problem and correct it be a worth while undertaking for both ride comfort as well as trans health. "Embarrassment factor" in there too of course, poorly shifting trans can have wide range of effects! Engine falls on face just at the wrong moment and all because it shifted when it shouldn't have....or didn't would it should have etc...
FORDF3502011
6.7L Power Stroke Diesel
15
Sep 14, 2011 03:11 PM
95Bronk
Dec 1, 2010 07:00 PM
deemac
Jul 28, 2010 06:34 PM
skidford
Dec 7, 2006 09:13 PM
ARNO60
Dec 22, 2003 10:42 AM
