Brick Nose Core Support
Old Jan 13, 2014 | 07:31 AM
catbird7's Avatar
catbird7
I have not disassembled my truck yet however you can clearly see the cab is lower on the driver side than the passenger. The rubber mounts visible from underside are in bad shape as well. My goal is to replace all of the rubber body mounts with factory like rubber replacements (no urethane) and repair or replace any damaged / rusted out mounting areas (cab mounts & core support). Since these core supports commonly deteriorate around the mounting surface between cab and frame, you would think someone would create a repair kit??? BTW, I'm in central PA.
Dirtboy953b
32
Dec 28, 2014 05:20 PM
mikeismadness
16
May 9, 2014 04:22 PM
Casesergelman
Mar 10, 2014 11:52 AM
Montanagrizzly
Dec 8, 2010 04:08 PM
rmalottwtes30
May 31, 2008 12:25 PM
