Batteries
Old Jan 7, 2014 | 10:00 AM
brandon.edwards's Avatar
brandon.edwards
Batteries
What should voltage be on my batteries when they have sat overnight, and i come out to start it up? What is normal operating voltage after it has warmed up?
When i go and start my truck usually after ive let it sit at work after my 12 hr shift, it start/cranks slow and always fires right up, but the voltage lags around 11.1- 11.2 and the battery light comes on. After a couple seconds go by the battery light goes out, the voltage jumps to 13.2- 13.9 and the idle goes to normal. I thought i may have had weak batteries, but went in to get em tested today, and they both checked out great.
Any thoughts?
Old Jan 7, 2014 | 11:22 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
May have both weak batteries and a weak alternator.
You should see around 12.6-12.8 volts at the battery @ 70 degrees. The colder it is the voltage drops. It wouldn't be uncommon to see 12.3-12.4 @ 32 degrees.
Old Jan 7, 2014 | 12:44 PM
IABill's Avatar
IABill
Talking
And if you decide to replace them ALWAYS change them as a set.
NEVER replace just one!!
Old Jan 7, 2014 | 08:25 PM
98SurplusExpy's Avatar
98SurplusExpy
I have new Motorcraft's; when I fire up my volts jump around from 11.6-12.0 ... after a few secs (assuming after GP's turn off), they jump to 13.5+.
Old Jan 7, 2014 | 08:34 PM
Fulthrotl's Avatar
Fulthrotl
Any thoughts?
your alternator is not charging your batteries past about 25% charge.
you need an alternator that outputs 14.5~14.8 volts. the OEM will never
do that. ever.
Pest007
Jun 15, 2019 06:36 PM
98SurplusExpy
Sep 21, 2013 12:01 AM
Ian123
May 6, 2012 01:40 PM
Cell's
May 3, 2011 12:45 AM
caere
Jul 14, 2010 11:48 PM
