Sponsored by: Real Truck
5.4L cold engine temp
Old Jan 15, 2014 | 12:03 PM
ashleyroachclip's Avatar
ashleyroachclip
Wd40 is a known method of drying electrical connections.
With your description , I believe your problem lies with either a bad boot or coil.
Old Jan 25, 2014 | 07:02 PM
Barret88's Avatar
Barret88
The problem went away for about 3 days and now its back and about as worse as ever. I replaced the coil I thought was bad , no change. Things I did when the problem started, I changed my thermostat got coolant all over the engine, and I changed my oil pressure switch. I had to move my air box to get to the oil pressure switch. Could a different coil be bad? Spark plugs? Mass airflow sensor? Fuel injector? Some other sensor? Vacuum line? Im puzzled and I need to get this fixed ASAP. No check engine light
MattP51
22
Apr 9, 2009 07:49 AM
learmoia
Dec 29, 2006 10:16 PM
felixr
Feb 14, 2006 10:49 AM
fatbob
Jan 26, 2005 10:08 PM
muscletruck7379
1978 - 1996 Big Bronco
Feb 14, 2004 07:57 PM
