When should a regen occur?
Old Jan 6, 2014 | 08:12 PM
ciscofreak's Avatar
ciscofreak
Lately my truck drives like the e-brake is on. Mileage is down quite a bit (13.5 average) and the truck falls on its face if you jump on the throttle before it takes off. It is even feeling like my old 6.0 with turbo lag.
I pulled out my AutoEnginuity and noticed the soot load % sitting around 27% but the truck regens every 150 to 200 miles like everything is ok. I remember hearing that DPF regenerations happen when the soot load hits 2%. Is this true?
Old Jan 6, 2014 | 08:59 PM
Romeo Scorpion's Avatar
Romeo Scorpion
No. It occurs when the soot count reaches 2.66 which is about 95%.
Old Jan 6, 2014 | 09:48 PM
ciscofreak's Avatar
ciscofreak
Thanks for the response. I guess I will have the truck looked at then for the turbo lag.
So the DPF waits until it is close to full before burning it off?
Old Jan 6, 2014 | 09:57 PM
Romeo Scorpion
100% isn't really "full". It can actually go up to about 300% before things start getting critical. In addition, some of the soot will burn off without an active regen if you drive it long enough at highway speeds, especially if you are pulling a load like a trailer.
Old Jan 6, 2014 | 10:01 PM
ciscofreak's Avatar
ciscofreak
Thanks. I learn something new every day.
Old Jan 7, 2014 | 05:58 AM
Bobbykjl's Avatar
Bobbykjl
How do you know when the truck is in regen?
I read about a message that flashes on the instrument panel but have never seen it myself.
Old Jan 7, 2014 | 06:46 AM
jonrjen's Avatar
jonrjen
The screen does flash an orange screen that tells you of the regen in progress. But, it only stays on the screen for maybe 3 seconds at the most. Ya gotta be fast and paying attention to see it. I have just under 8,000 miles on my truck and have seen the screen notice may be a handful of times.
Old Jan 7, 2014 | 07:04 AM
Romeo Scorpion
I have an Edge Products CTS. With that I can monitor the soot count, soot percent, DPF pressure and a whole host of other engine parameters and readings. I can also see when a regen has started and monitor it's progress.
Old Jan 7, 2014 | 11:08 AM
ciscofreak's Avatar
ciscofreak
If you interrupt the regen process enough, it will show "Drive to Clean Exhaust" and it will stay on the screen until you acknowledge it. It will then state "Regeneration Complete" in blue when done.
Best to drive when that happens and let the process finish.
Old Jan 7, 2014 | 08:21 PM
Bobbykjl's Avatar
Bobbykjl
Thanks for the responses.
So am I correct to say the only way to know if it's doing a regen is to either catch a glimpse of the screen or have a CTS hooked up?
Old Jan 7, 2014 | 08:26 PM
kper05's Avatar
kper05
While driving, yes.
If you are outside of the truck idling, it will smell like it's burning.
By putting it in park you've canceled the regeneration but that DPF remains hot for five or more minutes.
Old Jan 8, 2014 | 01:18 AM
F16Vip3r's Avatar
F16Vip3r
In addition to the CTS and the smell (and somewhat useless message), if you watch the instantaneous MPG you will see it drop considerably. At 60mph, mine will drop from 22mpg to 12, and stay that way for about 10-12 minutes.
Old Jan 8, 2014 | 05:21 PM
Dpica15's Avatar
Dpica15
My truck started cleaning the dpf just before i got home. Will it restart the cleaning next time i start the truck ( tomorrow morning ) ?
Old Jan 8, 2014 | 05:35 PM
kper05's Avatar
kper05
Depends on if it is still at or above 2.66 gpl of soot.
If yes, then it will begin again after oil temp is past 150°F.
However, if it heated for a few minutes, chances are it dropped to the 2.50 range and in that case, it will not run an AR again until at or after 2.66.
Old Jan 8, 2014 | 06:45 PM
Bobbykjl's Avatar
Bobbykjl
Sure enough, I saw the first Exhaust cleaning message flash. I was about 1 mile from my destination (work). I was a bit early so I decided to continue driving to complete the regen but I have no idea how long I have to keep driving? So I parked the truck and let it keep running while I went inside (now I know from the previous post it cancels the regen process).
Maybe I could watch the instant fuel mileage and wait for it to return to normal?
Maybe it's just not that important if it's interrupted and just pay no attention to it? Maybe that's how it's designed and it explains why Ford only provides the flash of the screen not to make us drive differently.
Lots of maybes here
