ICP?
Old Jan 6, 2014 | 07:02 AM
HKusp's Avatar
HKusp
Btw, how much fuel is in the tank right now?
Old Jan 6, 2014 | 07:27 AM
omahaford's Avatar
omahaford
fuel
I just filled up so damn near full
Old Jan 6, 2014 | 09:43 AM
HKusp's Avatar
HKusp
Well that eliminates the possibility that the fuel pick-up foot has a problem.
Old Jan 6, 2014 | 10:08 AM
Tact's Avatar
Tact
Oil in the ICP is not good and an indication that it is bad, or is going bad and needs to be changed. I would start there first, then change the CPS as that is a cheap attempt for the fix as well.
Mine acted similar and it ended up being the ICP, but I changed the CPS first and wasn't the issue. Now I have a spare.
Old Jan 7, 2014 | 05:59 AM
omahaford's Avatar
omahaford
Problem found
Fuel was horrible screens completely plugged and wore out the fuel pump only had 30psi. $1000 later and she should be running today.
Old Jan 7, 2014 | 06:05 AM
HKusp's Avatar
HKusp
Ouch, thats a lot of money. What all did they do?
Old Jan 7, 2014 | 02:14 PM
omahaford's Avatar
omahaford
C&C Performance Diesel
drained the tank all 35 gallons, New motorcraft fuel filter, cleaned screens, put in new $675 ford fuel pump and added 10 gallons of #1 diesel w/additive
Old Jan 7, 2014 | 02:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Sorry to be the bearer of bad news, but you got stiffed.
That pump is $150.
Bosch Electric Fuel Pump - Riffraff Diesel Performance
I'm glad the truck is running, but that should not have been a $1000 fix. Many forum members could do that in two hours.
Old Jan 7, 2014 | 03:27 PM
Dan V's Avatar
Dan V
He may have got jabbed...but unless he had time and a place to work on it.
One time I was picking up at the MSP airport, Delta cargo. I pulled into the lot, shut the truck off, brought my shipment to the counter...went out, truck wouldn't start.
Now I was pretty darn sure it was the CPS, but I neither had one, or had the tools to change it. Called a tow....6 mile tow to a Ford dealer. "Oh, we can't get to it today."....Um, it's 60 miles home....."We have rentals."
Well, they got a tech to have a quick look....yep CPS....$400 and I was on the road home. An hour out of my day.....done. That's back when CPS's were $100 items as well.
BillyBob69
20
Jan 27, 2015 07:48 PM
RustOrBust
Dec 2, 2014 11:56 PM
bigrig410
Aug 30, 2011 11:24 AM
kc 300EX
26
Feb 22, 2011 09:15 PM
Krisx125
Jan 9, 2010 04:27 AM
