Frame rust prevention
Old Jan 6, 2014 | 01:24 PM
DIYMechanic's Avatar
DIYMechanic
Wow that's a heck of a deal. I remember seeing pictures of your setup when you were doing one of your projects. I'd love to work my way up to a rig like that but for the amount of work I have to use it for, a 100lb unit is about all I can justify and even with that' I'll be waiting on my compressor until I can afford an upgrade.
Old Jan 6, 2014 | 01:28 PM
Grubbworm's Avatar
Grubbworm
Originally Posted by Diesel_Brad
my sandblaster costed a HELL of a lot more than 4-600. Mine was $6000 and the compressor was close to 10,000
I bought my current sandblaster/compressor used for $1200. Guy was no longer using it and wanted it gone
So, what you are saying is that you got a really, really good deal?
Old Jan 6, 2014 | 02:22 PM
Diesel_Brad's Avatar
Diesel_Brad
Yeah, SMOKING deal. It need about 400 in parts and I bought a fresh air setup(another 800) but it is kick ***.
I can do a WHOLE truck frame in about 2 hours. the 100lb put with the electric compressor takes ALL day
Sandblasting is the BEST means of cleaning and stopping rust
Old Jan 6, 2014 | 02:55 PM
dougbrown's Avatar
dougbrown
My problem is that I have very little down time to strip it down like that. It a landscaping rig. So at best I could have it down for a weekend. I think I'll just pull the bed early spring and por-15 it get the areas best I can with the sand blaster I got.
Old Jan 6, 2014 | 03:04 PM
Diesel_Brad
Take it to someone or have them come to you.
Strip what you can in day.
Have them sandblast the next day, you paint the SAME day
Reassemble the next day
Or just buy my truck, do what you want when you want then put dump body on
Old Jan 6, 2014 | 03:11 PM
dougbrown's Avatar
dougbrown
Is love to but I just not set on spending 4,500 on it if the frame is as scaly as u say. I'll just bring it to u once it striped. Again I have no time frame of when I will begin to get this done.
Old Jan 6, 2014 | 03:14 PM
Diesel_Brad
Does the truck get used in the winter?
And not a lot of $$ for a dana 60, 5 speed, t-case, low milage PSd, cab, utility body and lift gate, 6 like new tires
Old Jan 6, 2014 | 03:24 PM
dougbrown's Avatar
dougbrown
Truck is my daily driving rig. Jeep was suppose to be my back up. I know what your asking is not bad at all. I'm just saying it I don't have a pocket full of $$$$
Old Jan 6, 2014 | 03:54 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
for what its worth (not that it helps anyone at this point), I'll have some good experimental results with the Eastwood rust treatment products after this winter is done.
when I had my midship tank out for replacement, I wirebrushed everything I could easily access, sprayed a coat (about 2 cans) of their Rust Converter, let that sit for ~2 days per instructions, sprayed a coat of their Rust Encapsulator, then sprayed 2 coats of their Extreme Chassis Black. it was all single part rattle can stuff, but the cost was reasonable and at midwinter its looking pretty good under there.
I also did a few random spots with just the Rust Encapsulator to see how it would hold up on its own.
once winter is over, i'll decide if i'll do the rest of the frame this way or try something else - when I finally do my bed and engine swaps.
I have bought a small gravity feed blaster in the meantime and plan to get a decent spray setup together before the next round, though.
Old Jan 6, 2014 | 04:27 PM
dougbrown's Avatar
dougbrown
Please let me know how that goes.
Old Jan 6, 2014 | 06:13 PM
OldWoodsDiesel
Will do! Once it looks like the last road salting has occurred, I'll spray it all with water and see what we have...
Old Jan 6, 2014 | 06:48 PM
Diesel_Brad
I had NONE of the problems they spoke of in the article conceding the POR15 but here have a read
POR 15 Vs Rust Encapsulator - Products Comparision Part 1
madscientist
Jul 29, 2015 01:25 AM
Trojan8975
Jun 28, 2011 09:24 PM
Icefan71
General Automotive Discussion
Apr 10, 2011 07:49 AM
snubber
Paint & Bodywork
May 3, 2008 05:27 PM
tastyklair
Paint & Bodywork
Aug 14, 2006 08:46 AM
