cutting out???
Old Jan 5, 2014 | 03:29 PM
thornton1979's Avatar
thornton1979
cutting out???
A 1994 f350 460 efi 4x4 truck will run good some days and ithers it will cut out under load. Also will do it wen u floor it. Not a clue wats wrong. Has good fuel*pressure. And has good pressure wen running. No vacume leaks. Some days it will run its *** off. Any ideas?? Im thinkin about converting it to carburetor
Old Jan 5, 2014 | 03:39 PM
kermmydog's Avatar
kermmydog
Smile
What is good fuel pressure? How about the pressure readings.
Old Jan 5, 2014 | 04:10 PM
thornton1979
Fuel pressure spec is 35 -45 key on engine off. And spec running is 30 -40. I had 38 engine off and 34 enhine running.
Old Jan 5, 2014 | 06:01 PM
eakermeld's Avatar
eakermeld
Hook up the gauge and take it for a drive and see what it is running down the road at WOT.
Old Jan 5, 2014 | 06:14 PM
88LX5.0H's Avatar
88LX5.0H
When's the last time it had a tune up?
Dump the codes. Entirely electronically controlled engine. It will tell you where to start.
JohnnyMantic
Dec 18, 2013 06:27 PM
guitarpicr
16
Jul 4, 2012 10:57 PM
fireplow970
Nov 11, 2006 06:18 PM
mike L
Sep 27, 2004 07:23 PM
kevinrf250
Oct 15, 2003 11:06 PM
