6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
power steering pump
Old Jan 5, 2014 | 09:34 AM
mollikate's Avatar
mollikate
power steering pump
my 08 350 is gently chasing rabbits while hauling little less noticeable empty I have checked tie rods and all joints is it possible the pump is going
Old Jan 5, 2014 | 09:56 AM
bubbasz1's Avatar
bubbasz1
I would check the steering gear box, if the pump was going it would be hard to stop and steer. Sounds like something has some excessive slop, how are the tires wearing?
Old Jan 5, 2014 | 09:59 AM
mollikate's Avatar
mollikate
seems to stop fine and steering is very responsive no whining sounds just seems to wander more noticeable when at operating temp
Old Jan 5, 2014 | 10:00 AM
mollikate's Avatar
mollikate
new tires they are wearing perfectly
Old Jan 5, 2014 | 10:01 AM
mollikate's Avatar
mollikate
best way to check steer gear box?
Old Jan 5, 2014 | 12:08 PM
bubbasz1's Avatar
bubbasz1
Did it by chance start when you got the tires?
You need two people, your looking for slop, start with the steering gearbox, if that looks OK, check all the steering joints.
With the truck not running move the steering wheel back and forth, but your only looking for slop, once you feel pressure stop and turn back the other way. Now your always going to have a little slop, say a inch or so, if you have more you need someone to turn the steering wheel back and forth in that slop area while you go looking for the slop. Start with the steering gearbox and work yourself along all the joints until you find the issue.
You might not have any looseness which would mean maybe it's time to have your alignment checked.
Let us know what you find out.
Old Jan 5, 2014 | 02:01 PM
mollikate's Avatar
mollikate
looking back tires seem to be part if not all issue will have rotated tomorrow to rule out found no slop steer gear maybe if not tires
Old Jan 5, 2014 | 06:41 PM
wp6529's Avatar
wp6529
If the new tires have weaker side walls - taller tires, lower load rating, etc. they can definitely feel like they are wandering compared to the previous tires. It's also not unheard of to have a defective tire, even new.
jgdrcr
May 6, 2015 12:53 PM
dvdgzzrll
Oct 17, 2010 06:47 PM
baily034
Aug 1, 2006 12:44 PM
LARIAT 85
May 14, 2006 06:18 PM
