Tail gate latch
Old Jan 5, 2014 | 09:16 AM
raven3's Avatar
raven3
Tail gate latch
On 73 F250 tail gate latch mechanism is so worn that the latching bars fail move enough to release from the catch plate.
Believe the pins and holes in the linkage are elongated causing excessive play.
There is no access plate on the inside surface.
How is this mechanism removed?
Old Jan 5, 2014 | 11:03 AM
mikeo0o0o0's Avatar
mikeo0o0o0
There should be four bolts (basic p/n 382127-s) on the inside surface of the tailgate that you unbolt to remove the handle/latch assy.
Here's the illustration from the parts catalog showing the latch and links for the tailgate.
File Type: pdf
Old Jan 7, 2014 | 12:29 AM
raven3's Avatar
raven3
Thank you
The graphic really helps to understand how to remove the center mechanism that is totally worn out.
Old Jan 7, 2014 | 01:57 AM
rockittsled's Avatar
rockittsled
this might have some bearing on yours
https://www.ford-trucks.com/forums/1...-question.html
I bought the repo handle and it bent after less than 3 mos, if you can reuse your handle or find a NOS handle, do it. the clips and rods took up most of the slack anyways
Old Jan 7, 2014 | 08:10 AM
raven3's Avatar
raven3
thank you for the help.
From the exploded graphic looks like there are four separate metal to metal contact points.
1. handle hinge pins
2. handle notch
3. rotating device clevis hole
4. latch slot
looks like #1 & #3 are the most likely contacts for wear.
axelgawn
Mar 18, 2016 02:24 AM
nitro3421
6.7L Power Stroke Diesel
Sep 6, 2015 08:59 AM
Slip ford man
Feb 5, 2011 10:43 PM
Ford1988Trucker
Aug 3, 2010 05:02 PM
EBrown
1983 - 2012 Ranger & B-Series
Dec 20, 2006 05:53 PM
