fuel leak
Old Jan 5, 2014 | 07:55 AM
Liquid10Rider's Avatar
Liquid10Rider
fuel leak
Hey guys i just noticed a fuel leak at the back side if the fuel bowl and ours dropping into the valley. I believe it is coming from the fuel shutoff valve and the sensor next to it. are these both repairable with the fuel bowl rebuild kit or do I need to do something else to fix this problem once I run the truck again I will confirm where the leak is coming from but I believe it is coming from the valve itself.
Thank you,
AJ
Old Jan 5, 2014 | 08:00 AM
1996pwrstrk's Avatar
1996pwrstrk
It's more than likely the o-rings in the drain valve this link should fix you up.Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Old Jan 5, 2014 | 09:22 AM
whitetmw's Avatar
whitetmw
+1 - Easy fix
Old Jan 5, 2014 | 09:38 AM
mueckster's Avatar
mueckster
I do agree the drain valve is the main culprit. If you have the time and the kit, I'd pull the bowl and rebuild the entire thing. In your pic, it looks like the fuel lines on the passenger side may be weeping also. With the bowl out of the way, you can look more closely at the status of your HPOP, too.
Old Jan 5, 2014 | 09:53 AM
mechelement's Avatar
mechelement
http://www.dieselorings.com/1999-200...owl-parts.html
Buy your orings there. I highly recommend the entire fuel bowl rebuild kit and the billet FPR. My FPR did not break, but the new one is quality. I bought a new drain assembly as well. Blue orings on everything available all new sleeves for fuel fittings.
I thought the removal and install of the fuel bowl was a PITA. I got used to it around the end of the install. I could do it in 1/2 the time now.
Old Jan 5, 2014 | 10:12 AM
cj45lc's Avatar
cj45lc
If you can't wait for the entire fuel bowl rebuild kit from Guzzle you can get 2 #202 o-rings from any hydraulic shop ( I got them at a Parker Hyd.Store ) for $.68 to get you through til warmer weather
Old Jan 5, 2014 | 10:16 AM
Pikachu's Avatar
Pikachu
You might be able to stop the leak temporarily by tightening the 4 T-20 screws up a little bit. It could buy you some time at least.
xrsfsho
Oct 1, 2017 09:20 PM
grif95
Nov 13, 2016 09:09 PM
BigRed1Ton
40
Feb 14, 2016 01:49 PM
jacob_powerhouse
13
Nov 22, 2011 09:12 AM
rpenterics
Dec 10, 2010 02:45 AM
