Melted UVCH?
Old Jan 4, 2014 | 07:02 PM
FamilyWagon's Avatar
FamilyWagon
Melted UVCH?
I just bought an 00' excursion 4x4 with 7.3 diesel. My wife wanted one for a long time, and 5 kids later we finally had to get one. 10 days after the purchase she started running real bad and seems as though only 4 cylinders. I found this site while trying to diagnose the problem and couldn't believe how supportive the members are. I tried the .50 cent repair after some trouble shooting and found a melted UVCH on passenger side? I read dozens of post on this issue and never heard of one case like this. Can anyone make me smarter?
Old Jan 4, 2014 | 07:09 PM
carltonwebb's Avatar
carltonwebb
If its the center plug, it happens, usually from a loose connection. Do u have any pics you post to somewhere like photobucket and then put the link here?
Before u get the new harness, keep in mind that some members have reported issues with Dorman harness at some of the big box stores. It seems to be a quality issue on them putting the wires in the right place in the plug when they make the harness.
Old Jan 4, 2014 | 07:19 PM
FamilyWagon
I'll get some photos when the sun comes back out. The burn mark or melted portion looks like a hot cigarette burn on the top of the UVCH toward the fairewall side. I was really hoping it just came loose but that's not my kinda luck!
Old Jan 5, 2014 | 06:40 AM
F350-6's Avatar
F350-6
Subscribing to see the pictures. Melted plastic usually comes from a short. Either a loose connection or a chaffed wire causing a short as it rubs against metal.
Melted plugs were more common on the earlier version 7.3 trucks, but it can happen to this model as well. Most of the time it's just a loose connection that caused it.
Old Jan 5, 2014 | 05:02 PM
FamilyWagon
I don't know if this photo is going to work out, here goes. Notice the lower left side of the clip.
Old Jan 5, 2014 | 05:15 PM
Jesser02EX's Avatar
Jesser02EX
No photo try again
Old Jan 5, 2014 | 05:33 PM
FamilyWagon
http://s924.photobucket.com/user/Cha...28022.jpg.html
Old Jan 5, 2014 | 07:20 PM
F350-6's Avatar
F350-6
It's kind of hard to see due to the light in the photo, but I'm guessing you're going to need a new valve cover gasket. Unplug the connectors and pull it out. See if you don't have one or more burnt pins in the pass thru connector.
Did you have a check engine light with glow plug codes that showed up?
Old Jan 5, 2014 | 07:38 PM
lindstromjd's Avatar
lindstromjd
Time for a new valve cover gasket, and possibly inner GP/Injector harness. There's an updated version that gets rid of the inside connection on the valve cover, so it eliminates the need for a $.50 mod.
Old Jan 5, 2014 | 08:28 PM
FamilyWagon
I never ran the codes, I know I should have but after reading how common the UVCH problem was, I was racing to fix it for .50 cents! I had already bought a new motorcraft inside harness plug deal. I didn't think to get the gasket kit, that's the newb in me. I'll update what happens by wed. All I can say is I sure am glad it isn't lifted what a chore to get comfy wrenching on these, the last time I wrenched it was on old cars with lots of room and access, time to man up!
Old Jan 5, 2014 | 10:03 PM
timf150's Avatar
timf150
Check out post #14 on the following thread.
https://www.ford-trucks.com/forums/1...ing-badly.html
Tugly shows a burnt pin right in the center of his UVC Harness. Pehaps you had an enhanced case of what he experienced.
Tim M
Old Jan 6, 2014 | 09:11 PM
FamilyWagon
I talked to my fleet manager at work today, we've always had PSD work trucks until this year they started buying F150's. Anyhow he said if it were him, he would change the GP's and the injector cups? while I have it opened up. The X has 225k and he says the injector cups start going around 250-300k. My question is, do I apply the if it ain't broke don't fix it logic? or the since I'm already in there logic?
Old Jan 6, 2014 | 09:16 PM
lindstromjd
Originally Posted by FamilyWagon
...My question is, do I apply the if it ain't broke don't fix it logic? or the since I'm already in there logic?
Depends on how you look at it. These engines are kind of a pain in the a$$ to tear down to get to the injectors. (or at the very least, I hate doing them. TETO). It's your money, your time, and your truck.
Old Jan 6, 2014 | 09:43 PM
sm350bl's Avatar
sm350bl
The 7.3l is so much easier to get to the injectors and under the valve covers in a pickup platform vs the econoline. The heavier trucks/vans that are ran hard day in and day out will go through injector sleeves in that timeframe I agree. Typically they seem to last much longer in lighter not worked so hard applications. I would say fix your problem at hand with the new valve cover gasket and under valve cover gasket harness and take the other issues as they come if they ever do.
Old Jan 7, 2014 | 05:58 PM
F350-6's Avatar
F350-6
Glow plugs have a lot to do with the region and how often and hard they are used. North Dakota and Texas will go through glow plugs at different rates.
My injector cups have over 460,000 miles on them, so for the cups, I'm in the camp of if it ain't broke. For the glow plugs, I'm in the camp of, if they're getting old and the weather is nice outside, and you've got some time on your hands, then it's not a bad idea (avoid autolite plugs). Otherwise, if it's cold outside or your busy, and it ain't broke......
eddienelson
Jan 12, 2019 12:53 PM
Apocalypse
Jul 28, 2017 01:02 AM
ChrisMelton78
May 24, 2016 12:14 PM
Surflaunch
Apr 6, 2015 09:20 AM
weezer4117
Jul 13, 2012 10:48 PM
