GEM Harness - desperate earch
Old Apr 5, 2015 | 09:14 PM
Surflaunch's Avatar
Surflaunch
Long story finally coming to an end and caught a snag.
The issue is: I need the part of the wiring harness that plugs into the center section of the GEM module.
How I got here: I spliced two trucks together.
Truck 1, the sheet metal & interior doner, was a Silver 1999 V10 F350 4x4 XLT. Immacculate shape but engine, trans & fuel system was vandalized & 190k miles.
Truck 2, The chassis & engine donar, was a Black 7.3 F350 4x4 XLT Rusty sheet metal but the classic 7.3 package generally in good running order w 140K miles.
After a few months of swapping everything inluding the dash harnesses, instruments and all new computers, ECM, ICM and GEM.
My son made a deal to sell all that was left even though we weren't quite done. We thought we had all the doner parts swapped. Huge mistake.
Turns out there is no center plug for the GEM in the harness now. It can't be much or I would have noticed it but it must have gotten separated from the dash harness in the process of disassembly.
Anyone have any insight on a source other than just calling every salvage yard in the country.
Regards,
Surflaunch
FMD
Old Apr 5, 2015 | 09:22 PM
Baatzy's Avatar
Baatzy
Are you sure it is supposed to be there? On the truck in my signature I do not have a middle plug in my GEM. I would give FICMrepair.com a try though, Ed can get OEM parts for a decent price.
Baatzy
Surflaunch's Avatar
Surflaunch
Project photos
Size:  62.0 KBName:  imagejpeg_2_4.jpg
Some pics of the cab lifting and the original GE
Old Apr 5, 2015 | 09:29 PM
Baatzy's Avatar
Baatzy
I should clarify, I have the exact same plug setup on my GEM as is shown in the pictures above, but there is not male plug on the wiring harness to go in the center female plug on the GEM. Are you certain that the wiring harness from the 7.3 had a plug for that area?
Baatzy
Old Apr 5, 2015 | 09:33 PM
Surflaunch's Avatar
Surflaunch
Baatzy,
Honestly, no, I am not sure it is supposed to be there but I am getting a code that implies there is a GEM connection missing.
I thought I was pretty careful to take everything out of the diesel dash and transfer it over.
We did replace the GEM with the one ford said is correct. The original number was no longer available the new one was supposed to be the replacement.
Old Apr 5, 2015 | 09:41 PM
Baatzy's Avatar
Baatzy
What code are you getting?
I don't really have any clue what that middle plug does. I think it would be pretty hard to misplace that plug from the wiring harness unless you did a lot of trimming in the harness. Maybe someone else who knows more about the electrical side of these beasts can tell us if the middle plug is needed. Otherwise I would think you could call up Ford and see if they say you need it. I tried looking on fordparts.com but my computer is acting up so I couldn't get the parts diagrams pulled up.
If it turns out you do need it you could try car-part.com for used or talk to Ed at ficmrepair.com like I mentioned earlier.
Looks like you guys were having a fun time though. Is the new built truck up and running?
Baatzy
Old Apr 5, 2015 | 09:53 PM
Surflaunch's Avatar
Surflaunch
Message says
C241 HARNESS MISSING
Dash Wiring Harness part number is
XC35-14401-P260W
Had HN on a red tag on the harness
Old Apr 5, 2015 | 09:57 PM
Surflaunch's Avatar
Surflaunch
The truck is up and running but the instruments and some of the accessories are not working right.
Old Apr 5, 2015 | 09:58 PM
Surflaunch's Avatar
Surflaunch
Gotta crash for the night but I'll be on this till it's solved
Old Apr 6, 2015 | 09:20 AM
Baatzy's Avatar
Baatzy
I tried to look up that PN on fordparts.com but got a message saying they didn't recognize the number. I dunno whats up with that. I wish they did better with their parts website, something like Deere has with theirs.
Doing some digging on that code you found it appears to be talking about the lower connector on the GEM if you are looking at it in the pictures above, the connector with two rows of all straight pins, none of them are offset up or down. In the wiring diagrams this connection is referred to as GEM C241. I would check that again, maybe pull it apart and clean everything.
What are you using to pull codes? Thats the first time I have seen a code with only 3 numbers after the letter. GEM C241 is not even listed in the GEM DTC list.
On top of the other stuff I already mentioned, what all are you having issues with not working?
Baatzy
otnot
Dec 12, 2016 01:54 PM
homenf
WTB - Parts & other
Sep 26, 2016 04:10 PM
Diesel_Brad
16
Feb 11, 2015 11:01 PM
Michael Manglos
Feb 8, 2014 11:22 PM
rdking96
Feb 6, 2004 07:44 PM
