1978 - 1996 Big Bronco
4wd to 2wd
Old Jan 4, 2014 | 01:15 PM
92will460's Avatar
92will460
4wd to 2wd
Hey everyone I have a 92 f350 with 460. It's an automatic transmission with a Manuel 4wd shift. I can get it into 4wd but have a lot of trouble getting it out. Also the 4x4 light is always on and I know it's out because the front drive shaft isn't spinning so if you guys have any tips or anything that be great. Thanks
Old Jan 4, 2014 | 04:34 PM
gatorfor88's Avatar
gatorfor88
When shifting out of 4x into 2x try putting truck in reverse,and backing up a few feet. As for the light, that could be an electrical glitch
Old Jan 6, 2014 | 02:36 PM
bra$$monkey's Avatar
bra$$monkey
yes - if the truck is rolling it will disengage much easier.
Old Jan 7, 2014 | 10:09 AM
Encho's Avatar
Encho
The Southernmost Mod
Or the transfer case is having problems, you might have to open and see how are the internal forks, do a search on BW 1356 (I'm sorry, it probably isn't this one, but a heavier BW) rebuilds and you'll find out what I'm talking about. Is that case an electric shift or a manual?, the motor could be gone too, also, the ATF level is quite important, it needs 2 qts.
Old Jan 9, 2014 | 09:20 AM
rla2005's Avatar
rla2005
Your truck should have a 4x4 shift lever position switch on the front of the transfer case. Sounds to me like it is stuck closed.
Dseavy
Aug 17, 2018 11:34 AM
Memphis_Sean
20
Mar 8, 2015 03:17 PM
PSDlongbox
Sep 17, 2013 08:20 PM
topfisherman
Jan 2, 2006 09:29 AM
riksco
Bronco II
Nov 29, 2004 09:34 PM
