Steering gear box
Old Jan 3, 2014 | 09:14 PM
bearhugger's Avatar
bearhugger
Steering gear box
Anything special that I need to know about replacing the steering gear box on my 1995 f350, thanks. Jim
Old Jan 3, 2014 | 10:01 PM
ReBilld's Avatar
ReBilld
When you re-install the pitman arm on the new steering box, don't hit it with a hammer or anything. The box is easily damaged that way. use the nut to press it back on.
Old Jan 3, 2014 | 10:12 PM
farmert's Avatar
farmert
It is pretty straight forward, Having a pickle fork to remove the tie rod from the steering arm, and a puller to remove the arm from the gear box is very helpful. It can be done without these two items, but it is a LOT easyer with them. 3 bolts hold the box to the frame, 2 hose fittings, and 1 bolt threw the rag joint to hold it on.
Old Jan 3, 2014 | 10:48 PM
mudmagnet63's Avatar
mudmagnet63
Are you buying new or rebuilt? I'm needing to do something on mine soon.
Old Jan 3, 2014 | 11:04 PM
ReBilld's Avatar
ReBilld
They cost a little more, but if you can swing it, these are supposed to be the best you can get.....
Red-Head Steering Gears
Old Jan 4, 2014 | 05:36 AM
427 fordman's Avatar
427 fordman
Good to see ya Jim. I agree with Bill, if you can get a redhead box, they are the best.
Old Jan 4, 2014 | 08:26 PM
bearhugger's Avatar
bearhugger
Thanks guys,I will probable buy the rebuilt one and I did look at the red head one,o Reilly has one for about 150.00 with life time warranty,mine works ok but just trying to stop some leaks. Thanks for all the info. Jim,
catzr440
Oct 19, 2016 01:03 PM
72CC428
Apr 29, 2016 02:11 PM
acw592
Dec 3, 2009 09:16 PM
FordF350Baby
Sep 5, 2009 09:25 PM
wolftan
May 21, 2009 03:08 PM
