Hard Shift Into Second
Old Jan 2, 2014 | 06:08 PM
Subzero68's Avatar
Subzero68
My truck sometimes has a hard shift into second gear before it get thoughly warmed up. After not being driven for some time the intial first-second shift is rough depending on how much throttle is applied before/while it's shifting. I want to run this trans for as long as it will go and for the amount of miles on the truck it's very smooth. Fluid level and color is great. Whats the best thing for me to do to make the most miles out of it?
Old Jan 2, 2014 | 06:19 PM
9228.bobcat's Avatar
9228.bobcat
Change external filter every 20k miles. If cold it wont shift super fast into 2nd Just take it easy on the throttle until it warms up a bit.
Old Jan 2, 2014 | 06:20 PM
69cj's Avatar
69cj
What is the service history, type of fluid in it, miles and year of truck? You don't give much info for people to work with.
Old Jan 2, 2014 | 07:57 PM
Subzero68's Avatar
Subzero68
I just picked the 03 F250 up almost a month ago. It's got a few thousand over 200K. I haven't heard much about the external filter, but now that you mention it I'll look into it. Probably not a big deal with the shifting as it's got to be expected with so many miles on it. If it gets to 300K I'll be happy as can be ( the trans that is).
Old Jan 3, 2014 | 04:09 PM
Subzero68's Avatar
Subzero68
I took the truck to see if all the recalls were done at Ford and it turns out that a programming recall for shift points was needed. We'll see if that helps.
Old Jan 3, 2014 | 07:01 PM
Money-Pit's Avatar
Money-Pit
Do you have any tunes on the truck? There are some tunes out there that will eat trannys.
Old Jan 3, 2014 | 09:04 PM
Subzero68's Avatar
Subzero68
No tunes, a tuner was on the truck but only for less than 8,000 miles. Shop said no I'll effects from it when I had it removed and reflashed to stock.
outofhours
Aug 27, 2017 09:37 AM
M fire
22
May 17, 2015 01:27 PM
dfishrmn88
1997 - 2003 F150
Jun 17, 2005 11:23 PM
Pastmaster
Mar 26, 2002 08:59 PM
