New Radiator leaking!
Old Jan 3, 2014 | 06:23 PM
Island'r's Avatar
Island'r
Just replaced my rad last year with a Spectra premium... Now this one is leaking at the fitting where the upper trans cooler line goes in... (leaking coolant)
I checked the fitting and the large 1-1/16" brass nut was loose... I snugged it down, but it is still dribbling out just as bad
Anyone know what seals those fittings?
I really don't wanna fork out another $200 for a new rad... But I might just have to...
Was gonna say screw the Chinese Junk... Just phoned ford to get a price from then, but this rad is now obsolete through them...
Old Jan 3, 2014 | 06:29 PM
Diesel_Brad's Avatar
Diesel_Brad
Get the Ford part number and google it, I bet there are some out there.
Where diode you buy the Spectra? I believe they have a lifetime warranty
Old Jan 3, 2014 | 06:57 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Can you add any thread sealant to the threads?
Old Jan 3, 2014 | 07:18 PM
Island'r's Avatar
Island'r
Yeah, that is an option, though I'm guessing they'll be a pretty penny. Ford said if he did have one it'd be $890 + tax... I got the spectra for $190 out the door... I gotta dig the warranty paper out that came with it... I think it was 2 yr warranty...
Of course there was a little tag on the radiator that said, "Warranty Void if this tag is removed" It has fallen off
Possibly... But I just went out and fiddled with it... Took the nut right off, and it looks like there is an O ring between the plastic rad tank, and the brass portion of the internal trans cooler... it was off center, and kinda squished out to ine side, so I straightened everything up, and snugged up the nut again. SEEMS to not be leaking, but I will have to check it tomorrow...
I think its been dribbling when cold for a while... I noticed this week that I could hear a bit of air gurgling in my heater core at startup... The fact the rad was low would be why... Obviously stopped leaking once warmed up or I woulda had some major leakage/steam going on...
Fingers crossed...
Old Jan 3, 2014 | 07:20 PM
Diesel_Brad
Somone posted a link to a Ford rad on ebay for these trucks a lil while ago. $89 buck BRAND NEW
Old Jan 3, 2014 | 08:07 PM
easy bleeder's Avatar
easy bleeder
I just replaced the old radiator in my 1989 and ended up with a leak in the exact same place as you. I just put a couple wraps of the Teflon pipe tape on the threads and wa-la no more leaks. If yours continues you might want to give that a try. Good luck
Old Jan 3, 2014 | 09:11 PM
joey2fords's Avatar
joey2fords
Of course there was a little tag on the radiator that said, "Warranty Void if this tag is removed" It has fallen off ...
gotta wonder how many of those tags survive past the first few months. brilliant business plan .
Old Jan 3, 2014 | 09:21 PM
Evan_P's Avatar
Evan_P
The number looks to be F2TZ-8005-KACP for the 7.5 W/E4OD. Can't find it anywhere though...
Old Jan 4, 2014 | 10:18 AM
Island'r's Avatar
Island'r
Originally Posted by easy bleeder
I just replaced the old radiator in my 1989 and ended up with a leak in the exact same place as you. I just put a couple wraps of the nylon pipe tape on the threads and wa-la no more leaks. If yours continues you might want to give that a try. Good luck
Hmm interesting... Was it a Spectra brand as well? I don't remember checking the tightness of the rad fittings when I installed maybe they are not snug from the factory... You would assume they would be properly torqued... I should know better than that...
Brilliant indeed... Lets put a paper sticker on a piece of aluminium, that gets hot, and sprayed with water...
There is also something in the warranty about having to flush the old system to remove ALL sediment etc... I flushed the system good, but I'm sure no doubt they'd find an excuse to void the warranty so they can sell me another piece of junk
Old Jan 4, 2014 | 02:14 PM
boonslick's Avatar
boonslick
Radiator Leak
Hello and good afternoon.
I had the same problem although it only leaked enough to attract dirt, etcetera, and was black. I wire brushed the entire fitting and tightened it backing up the radiator fitting with a wrench while tightening the large brass nut and it is now leak free.
I believe that the fitting is a flared connection but I did not have it apart. The flare fitting does not have to be that tight nor does the radiator fitting. Use the "you can always tighten it more but once it is cracked it is too late."
Perhaps you could drain the Anti-Freeze into a clean container by loosening the large brass nut and be sure to "back up" the radiator fitting. When you have drained the Anti-Freeze remove the fitting from the radiator and clean the male and female threads. Perhaps you could use Teflon tape on the radiator fitting and just a couple of drops of 3 in 1 oil on the flare connection.
I do not know which thread sealant is best so perhaps some other Forum Members have the answer.
Take care.
Boon
Old Jan 4, 2014 | 06:44 PM
easy bleeder
Islandr I do not remember what the brand name was of the radiator I installed. But initially had the fitting as tight as I dared go with it the first time. You know, tighten until a bead of sweat appears then stop. Checked for leaks and it was as usual. Next day I put in a call to the parts outfit and asked them what they recommended and they said to wrap it in Teflon pipe tape and it worked out okay for me. Hope this helps
Old Jan 4, 2014 | 07:24 PM
Island'r's Avatar
Island'r
Well, I snugged the fitting as much as comfortable... Seems to be no leak. See the odd drip every 15 mins or so...
I think once the o ring re-seats it will be fine...
If it starts again I'll try the Teflon tape route...
Thanks for the suggestions!
Old Jan 4, 2014 | 07:47 PM
95F350XL's Avatar
95F350XL
I just ordered a full aluminum rad for 156 shipped for my 91 F350 with a 460. genesisautoparts.com
GCLL
6.7L Power Stroke Diesel
Aug 9, 2013 03:16 PM
chi6488
6.4L Power Stroke Diesel
May 20, 2013 06:03 PM
ruschejj
48
May 5, 2011 12:26 AM
ruschejj
42
Dec 21, 2009 12:32 PM
V10man
Jul 26, 2002 09:32 PM
