Anti Theft System
Old Jan 3, 2014 | 05:44 PM
Lost Yankee's Avatar
Lost Yankee
Anti Theft System
Is there any way to disable the anti theft system? Mine is active and I cant start the EX. I was able to reset it one time and that got me home but now she is dead in the drive way. The windshield might have leaked the other day during constant rain so I have a drop light under the dash, HELP lol
Old Jan 4, 2014 | 11:24 AM
RMBC Freeride's Avatar
RMBC Freeride
Do you have multiple keys for it? (I hope so). If so, try the other keys. Sometimes the chip in the key goes bad and the security module in the coulmn does not recognize it.
If that doesn't work, find a nearby member with AE software to help you reprogam it (and get extra keys programmed)
Or call the locksmith - most of them have software to reset and make new keys ($$$$)
Old Jan 4, 2014 | 09:24 PM
Stebs's Avatar
Stebs
if you can, try and pull the codes and see if the PCM is powering up. Also check all of your fuses as well...
Old Jan 19, 2014 | 11:24 AM
rarmbrust3's Avatar
rarmbrust3
when my PATS acts up i have to disconnect one battery for a minute and it will reset.
Old Jan 19, 2014 | 01:25 PM
projectSHO89's Avatar
projectSHO89
That's what is properly called a "coincidence".
Old Jan 19, 2014 | 02:17 PM
double ott ex's Avatar
double ott ex
you should put your year/make and model in your sig line so everyone will know how to best answer your questions. here is the section from the service manual pertaining to "pats" (passive anti theft system)and the wiring diagram for 2000 superduty trucks. not sure if it will help you or not.
https://www.dropbox.com/s/nuqc66vp6f...-00%20pats.pdf
https://www.dropbox.com/s/k7nxagu9e4...%20diagram.pdf
DOE
Old Jan 19, 2014 | 08:31 PM
snakedoc's Avatar
snakedoc
i dont know of any way to disable it with out some software.
Old Jan 20, 2014 | 07:15 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I would fix the leak and then you should have no problems.
phinfan1016
May 19, 2016 12:33 PM
goethemom
1997 - 2003 F150
Aug 22, 2010 02:15 PM
muskie770
Jan 3, 2005 02:22 PM
JH6
1997 - 2003 F150
Aug 27, 2004 09:41 PM
rotorhead
15
Aug 26, 2004 01:51 PM
